Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
Steffen80
21 Jun 2019 09:17
rick2018 schrieb:
18 meters long and 76,000 liters (20,066 gallons). We switched to a smaller one because it fits better in the available space in front of the pool. Originally, we wanted 90 m³ (3,180 ft³).
This way, we have more options for designing the garden to the left of the pool.
Why so large? We have 15 m² (161 ft²), and that size is already completely uneconomical. For that money, we probably could have paid for garden water for 20 years..
rick201821 Jun 2019 09:27
Last year, there was already a ban on using fresh water for irrigation. With a cistern like this, it’s not a problem.
Depending on your garden and the establishment phase, you can easily use 10m³ (350 cubic feet) of water per irrigation session.
To operate larger sprinklers or irrigation zones, you need a suitable pump with sufficient volume and pressure. Otherwise, it would be impossible to complete an irrigation cycle, for example, in one night.
You wouldn’t be able to manage this from the mains supply alone, nor keep up with refilling afterwards. Our pump would empty your cistern in half an hour.
This way, we can store enough water temporarily (from rain and well water).
The cost increases are not as drastic once the cistern reaches a certain size.
Our goal was to bridge at least 4 to 6 weeks.
From an economic standpoint, a single-family home is not cost-efficient anyway. We didn’t install this cistern to save money but to ensure good irrigation.
For what the pool costs, we could go to a public swimming pool for life. But that’s not what we want.
Mottenhausen
21 Jun 2019 09:33
Look up the annual rainfall per square meter in your region. Then multiply that by the square meters of roof area you direct into the rainwater tank and by about 4 €/m³ (4 USD/yd³) for freshwater plus wastewater costs. I estimate the rainwater tank would pay for itself in at least 30 years, assuming water prices continue to rise.
This comes at the expense of the environment and freshwater quality, because if everyone collects their own infiltration water, nitrate levels in groundwater will continue to increase.
A watering ban using freshwater? That’s surprising—I haven’t heard of that before.
haydee
21 Jun 2019 09:42
Mottenhausen, in some regions, cisterns are part of the concept to prevent flooding caused by heavy rain. And heavy rain events are becoming more frequent.
How cisterns will affect groundwater remains to be seen. Basements flooded with water are also far from ideal. I wouldn’t want to imagine what kind of pollutants could be washed into streams and rivers.
rick201821 Jun 2019 10:18
As haydee mentioned, retention cisterns are required in new housing developments to manage heavy rainfall by providing temporary storage.
We didn’t actually need a cistern but chose to have one anyway.
In our case, the water drains back into the ground quite quickly. Most of it will probably return to the groundwater source.
Last year’s watering restrictions, I believe, were only active for about 4-6 weeks. Still, it’s frustrating when you’ve invested a lot of money and effort in landscaping and then end up with a brown, dry yard.
Müllerin
21 Jun 2019 12:14
Last year, I was in OWL as well as in (Middle) Franconia, where there is generally little rainfall, and during summer this also happens more often.
(Fresh water watering ban for lawn sprinklers).
I find it annoying anyway; you can manage lawns and perennials again, but bushes and trees may occasionally need watering assistance.
