Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
Wickie
7 Jun 2019 10:49
Friends of ours also have some items from Gartenmetall, just came to mind. You can really browse nicely on their website as well!
hampshire
7 Jun 2019 10:52
off Topic – Alternative to Corten steel against slugs: stretch two iron wires 2cm (about 0.8 inches) apart parallel around the bed and connect to a 9V battery. The slugs turn away. Very inexpensive.
world-e
7 Jun 2019 10:55
With Corten steel, the rust layer actually protects against perforation. The copper content prevents snails from approaching because their slime becomes corrosive to them. This effect does not occur with regular steel or painted steel.
tumaa
7 Jun 2019 10:58
hampshire schrieb:
off topic – Alternative to Corten steel against slugs: stretch two iron wires around the bed in parallel at a distance of 2cm (1 inch) and connect them to a 9V battery. The slugs turn away. Very cost-effective.
I’m sure there are animal welfare advocates here as well.
haydee
7 Jun 2019 11:12
hampshire schrieb:
off topic – Alternative to Corten steel for keeping snails away: stretch two iron wires 2cm (1 inch) apart around the garden bed and connect to a 9V battery. The snails turn back. Very inexpensive.
Does not last long. If there is too much snail slime, you cannot recharge it quickly enough. A friend tried this and the battery lasted on average 3 days.
Lumpi_LE
7 Jun 2019 11:42
Then just plug it directly into the outlet; the sight alone will already deter the other snails.
