My wife wants a wooden deck suitable for barefoot use, so we chose Yellow Balau.
The delivery arrived yesterday: out of 29 boards, each 3.97 meters (13 feet) long, 2 are quite strongly curved in the middle, almost bow-shaped. The deviation is about 4-5 centimeters (1.5-2 inches). A few others are not completely straight either, but to my untrained eye, they are acceptable. A 5% defect rate is allowed, the supplier insists on this and also emphasizes that “wood is a natural material.”
Question: Is it possible to straighten these curved boards for use as decking? I have read something about using spacers plus a ratchet strap and screwing them down. Or are these two boards unusable?
AndreasPlü schrieb:
Would you do that, or is this standard?Somewhere in the delivery terms or similar, there should also be information about warped floorboards. This is not always a valid reason for complaint but must be accepted up to a certain extent because wood is a natural product. Depending on the classification and supplier, this varies. They can be installed, as described, but it takes a bit longer. And with 2 out of 29 boards affected, that is still quite manageable.
boxandroof31 Mar 2019 10:19dertill schrieb:
Since I've just been through this with several decking boards: Which boards did you end up installing? Thermally modified wood, larch, or something else? Are you satisfied with your choice?
boxandroof schrieb:
What type of decking boards have you installed? Thermo-treated wood, larch, or something else? Are you happy with your choice?I initially leaned towards thermo-treated pine or thermo ash but ultimately chose classic larch for several reasons.
The terrace is about 34 m² (370 ft²) in size. The price of the wood was an important factor since all other options would have been at least twice as expensive. I installed 28/120 mm (1.1/4.7 inch) boards without any profiling, so they are smooth. At the moment, I’m very satisfied. How long that will last remains to be seen. I followed the main guidelines for structural wood protection, so I’m not too worried about long-term stability in general. As for splitting or checking, we’ll see. Working with larch is also easier than with hardwoods, and since this is my first own terrace, I didn’t want to make things unnecessarily difficult or struggle with particularly expensive wood.
Here is a picture of the terrace. The photo is from February, so it wasn’t finished yet. On the right, you can see the wood pile. The decking was extended about 6.5 m (21 ft) to the right with boards that are 2 m (6.6 ft) long instead of the 4 m (13 ft) ones shown here. (The pergola was built by the previous owner).
@AndreasPlü what type of wood do you have?
boxandroof1 Apr 2019 10:00dertill schrieb:
I initially leaned towards thermally modified pine or thermally modified ash, but for several reasons decided on classic larch.Thanks for the feedback and the information!
When fastening from above, it hardly shows due to the wood grain. We had planned to make it hidden, but now I’m not sure if the effort is worth it.
We are also strongly leaning towards larch or Douglas fir. Unfortunately, the samples of thermally modified pine and wood/plastic composite materials that I had were not convincing.
