ᐅ Storm anchors for fence construction: Which side of the fence?
Created on: 19 Mar 2019 19:49
nadam1
nadam1
19 Mar 2019 19:49
Hello, I want to build a 20-meter (65.6-foot) long wooden fence on top of an existing concrete wall. I will use prefabricated wooden panels measuring 180 x 180 cm (71 x 71 inches). The posts will be fixed with screw-on H-anchors.
Since the panels are quite dense and the wind here can be quite strong, I have been thinking about adding storm anchors. I THINK they should be installed on the side of the fence where the wind does NOT come from, to stabilize the posts through counter-pressure.
But that would place me on the neighbor’s property... and they probably won’t be happy if I want to pour 30 x 30 x 80 cm (12 x 12 x 31.5 inches) concrete foundations for the anchors over there…
Is it possible to place the storm anchors on the windward side so they “hold” the fence posts?
Thank you very much for your answers.
hampshire
20 Mar 2019 00:42
You can stabilize the fence either by tension or by compression. Both methods are possible. It's just a matter of the technique used.
hanse987
20 Mar 2019 06:44
A different point. What does the building plan / planning permission say about the maximum fence height, and what does your neighbor think about your project?
Lumpi_LE
20 Mar 2019 08:04
Wind can come from any direction...
nadam1
20 Mar 2019 09:48
Ok, thanks...
The neighbor doesn’t mind (but I would still get that in writing).
Good point about the development plan... Thanks! (I had assumed that 1.80 m (5 feet 11 inches) at the property line was acceptable)
...I’ve now asked the building authority.
11ant20 Mar 2019 14:56
Especially storms do not necessarily follow the usual prevailing wind direction. When they rage, wind behaves more like a point than just a rocker.
