ᐅ Two semi-detached houses, one of which includes a separate granny flat (or accessory apartment).
Created on: 3 Mar 2019 16:31
E
Enkelkinder
Hello, I have a question: is it possible to build two semi-detached houses attached to each other, where one semi-detached house includes a granny flat and the other includes a basement?
We have a bigger problem finding a suitable plot of land where a three-family house can be built.
Thank you in advance for any information.
Enkelkinder4 Mar 2019 10:27
Thank you for your information. However, in general, it would not be impossible to build this way if the zoning plan / building permit allowed it. First, a suitable plot of land needs to be found. I think it should be about 1000 sqm (10,764 sq ft) for all of us, so that everyone can have a small garden and garages on it.
4 Mar 2019 11:38
Enkelkinder schrieb:
Thanks for your information. But in general, building like this wouldn’t be impossible if the local zoning plan allowed it. First, a suitable plot of land has to be found. I think it should be about 1000 sqm (10,764 sq ft) for us all, so that everyone can have a small garden and garages as well.
If I were you, I wouldn’t focus too much on that, especially if there isn’t an abundance of building land in your area. I’ve heard that plots of land don’t just grow back 😉 In new development areas, it is often regulated that single-family house lots may be built on with one residential unit and/or a single-family house with a granny flat (2 residential units). Designated semi-detached house lots are usually only allowed to be built with these 2 residential units, meaning 2 halves of a semi-detached house. It’s different in building gaps. With some luck, you might find a plot where more options are permitted. In the current case, a four-family house was discussed just a few weeks ago... there, three residential units would also be possible.
11ant4 Mar 2019 11:38
whether a granny flat can be built into one semi-detached house but not the other
The number of residential units may be limited by the zoning plan, but the building type "semi-detached house" does not necessarily restrict the total to just one pair of units, nor does it require the two halves to be identical (except sometimes the zoning plan may mandate matching profiles, roof pitches, eaves heights, or similar features).
4 Mar 2019 11:45
... the building type "semi-detached house" itself does not necessarily mean there are only two dwelling units combined, nor does it require the two halves to be identical (except sometimes when the building regulations/planning permission specify, for example, matching roof profiles / roof pitches / eaves heights or similar).
.... but only that both units share a continuous building structure 😉
