ᐅ Walk-in shower, seeking advice
Created on: 27 Jan 2019 12:45
LarsRud
We are planning a walk-in shower: 1.5 m (5 feet) wide and 1 m (3 feet) deep.
Since the architect designed the toilet in a way that makes access somewhat awkward, I have the following questions:
1) Where and how large would you make the shower entrance?
2) Is just an opening enough, or would you partially extend the wall into the shower as shown in the drawing? Or should a glass door be installed?
3) Or do you think leaving the side facing the toilet open and entering from there is better? I find that a bit too narrow and unattractive myself.
Thank you for your ideas and tips
Grundriss: Badezimmer mit Badewanne, zwei Waschbecken und Toilette; Flur und Treppenhaus.
Handskizze eines Grundrisses: Badezimmer mit Dusche rechts, zwei Wandabschnitte und Maßangaben.
Skizze eines Badezimmers-Grundrisses: WC links, Dusche mittig, Tür rechts.
Handgezeichnete Grundriss-Skizze: WC links, Trennwand, rechte Raumfläche mit Markierungen
M4rvin31 Jan 2019 22:41
Is this already considered a walk-in shower?
Floor plan of a residential section: Bathroom and Child's Room 2, doors, furniture, and dimension lines.
31 Jan 2019 22:50
M4rvin schrieb:
Is that now considered a walk-in shower?
No.
31 Jan 2019 22:52
Nope.
Let me correct myself: without a tub, without barriers: yes.
For me, it's a pseudo walk-in.
Andre77
31 Jan 2019 22:54
hemali2003 schrieb:
Drywall installation was a bit tricky to ensure the walls are stable.
May I ask what costs are involved with this kind of drywall construction?
hemali2003
1 Feb 2019 09:07
Phew, good question... I think the drywall part alone was around 1500 euros for two showers. But I don’t really remember. The prices aren’t very representative since we used a design and build contract. On one hand, some surcharges were particularly high, but on the other hand, omitted services were deducted.
Overall, I believe the additional cost compared to the standard for two showers (drywall, tiling, installation...) was about 5000 euros.
seth04871 Feb 2019 11:30
Initially, we kept the option open to install a shower door later and tried it without one at first.
We deliberately chose this T-shaped layout, and the shower splash guard is 1.0 m (3.3 ft) long. So naturally, there were a few splashes at the shower exit, but not really much.
However, we eventually decided to install a shower door because it felt too cold to shower without an enclosure. Of course, the entire room heats up over time, but that takes a while. And I don’t spend that long in the shower. I now find it much more comfortable with the (pivot) door. Maybe I’m just sensitive to that?!
The heated towel rail inside the shower is also practical (in the drawing it is shown in a different location; it is directly opposite the shower). This way, you have a pre-warmed towel within easy reach and can step out of the shower with dry feet.
Badezimmer-Grundriss: Badewanne rechts, Waschbecken unten, Tür links, Maße.
