ᐅ Ground floor approximately 100 sqm, upper floor adaptable for expansion (planned bathroom, 2 children's bedrooms, 1 storage room)
Created on: 28 Mar 2018 10:32
pffreestyler
Plot size: 879 sqm (9,458 sq ft)
Slope: no
Site occupancy index: 0.3
Floor area ratio: 0.45
Building envelope, building line and boundary: 5 m (16 ft) to the street, 3 m (10 ft) each to the orchard area and neighbors
Edge development /
Number of floors: 2
Roof type: gable roof
Construction style: solid / masonry
Maximum heights / limits: ridge height 9.0 m (30 ft), eaves height 6.0 m (20 ft)
Other requirements
Homeowners’ requirements: living room facing south, small office (initially used as a nursery), walk-in shower on ground floor, utility room on the driveway side
Basement, floors: no basement, 1.5 stories
Number of residents, age: 2 – under 30
Office use: family use rather than home office
Number of overnight guests per year: 2-3
Open or closed architecture: closed
Traditional or modern style: rather traditional
Open kitchen, kitchen island: no
Number of dining seats: 6
Fireplace: no
Music / stereo wall: no
Garage, carport: carport planned later on the east side
Designer: general contractor
What do you like most? Why? living room facing south, the number of rooms as desired
What do you dislike? Why? the office window 1 should be moved from south to west (otherwise the wall looks too bare); driveway and access to be on the east, not the west
Price estimate by architect/planner: available after Easter; currently mainly focused on the floor plan
Personal price limit including fixtures: expected around €1,700 per sqm (sq ft conversion not added per instruction)
Preferred heating: gas
If you have to give up, which details/features?
-can give up: bathtub
-cannot give up:
The floor plan is based on a very similar layout seen during a house viewing and is our favorite among all viewings and catalog research. We only adapted it slightly to our needs (removed guest WC and enlarged living room, rotated office).
The floor plan basically fits us, but I would appreciate your opinion to see if any improvements are possible. Note: as mentioned, we want to move the office window to the west so the wall doesn’t look so bare. Driveway on the east, not west. Therefore, the bare wall on the west is where the carport will go up to the utility room door. Alternatively, a window could be added to the living room there and the carport start behind the house. The plot allows this.
My main concern is that we’re not 100% happy with the roof’s east-west orientation; I would prefer a north-south alignment. Do you have ideas on rotating the floor plan 90 degrees while keeping the layout mostly unchanged? Only the kitchen and office could be swapped.
PS: The square meter figures for the hallway may be incorrect; the contractor will finalize after Easter. Correct figures will be approximately: living room 31.79 sqm (342 sq ft), kitchen 15.19 sqm (163 sq ft), utility room 9.87 sqm (106 sq ft), hallway about 19.5 sqm (210 sq ft), office/child room 1 about 8 sqm (86 sq ft), bedroom about 11.8 sqm (127 sq ft), bathroom about 8.5 sqm (91 sq ft)
Plot details: length west: 40 m (131 ft), east: 42 m (138 ft), width: 21.5 m (71 ft)
pffreestyler
4 Dec 2018 14:51
Sure, but we already need to know the exterior walls of the rooms now, as they might be installed at this stage. The interior walls will indeed be installed later, but we can at least start planning them a bit now.
4 Dec 2018 15:50
pffreestyler schrieb:
Yes, of course, but we already need to know the exterior walls of the rooms now, as these might have to be installed at this stage. The interior walls will indeed be built later, but we can already start planning a bit.
You are planning somewhat... without much consideration.
pffreestyler
4 Dec 2018 16:01
That is exactly why I am here.
4 Dec 2018 17:29
That's exactly why I'm here
Sorry, I meant that you are already considering moving rooms within the house...
Maria16
4 Dec 2018 17:38
Is a bathroom on the upper floor really necessary and essential?
11ant4 Dec 2018 18:16
Regarding the knee wall, I had made incorrect statements due to lack of knowledge. I think this shows that there actually is a small knee wall
You made incorrect statements about the position of the windows, and I would not call that a naive miscalculation.
Now I will slowly explain what can be seen in your picture. Namely, that a "k" is missing – you have no knee wall!
Technical drawing: diagonal line, green vertical line, pink dot, blue overlay.
I have shaded the exterior wall in blue, mentally extended up to the top edge of the ceiling joists. The red line shows the position of the absent ridge beam here. Its lower edge is exactly "0" above the blue area, meaning the knee wall height is 0.
The difference between the length of the green line and zero is simply due to the pitched section created by the roof slope. This is not a knee wall; it is just a simple plumb line following the pitch.
If you subtract the floor buildup at the base point of the green line, it will still be roughly estimated to be 12cm (5 inches) long—but that does not make it reasonable to declare a 1m (39 inches) line 88cm (35 inches) further up.
The design of the roof overhang itself is economical. Considering the current trend of boxed eaves, this is smartly designed for a laundry line attic (a polite way to say "the jerk who planned this as living space should publicly return their diploma").
If the conversion is not to become an illegal building, the planner responsible for getting it approved with proper insulation will have a tough job. Starting with the nonexistent exterior wall in the attic, it will be no easy task to properly seal this upper extension of the thermal envelope.
Your idea that adding battens on top of the rafters—which is necessary solely because of the thickness of the insulation layer—can be considered as the counter battens as well, is nonsense from the same source as the ten-centimeter floor thickness idea.
I find this concept of a couple’s apartment with a "build now, think later" attic irresponsible. A professional should have advised you strongly against it.
