We are planning to install a ground source heat pump.
Does anyone have experience with the maintenance of these systems?
Is there a regular inspection by the chimney sweep or anyone else to check the system?
Or put another way, are there any wear parts that need to be checked and possibly replaced periodically?
For example, the pump, any filters, etc.?
And what other operating costs can be expected?
Ostsee
Ostsee
In brine heat pump systems, the heat exchangers are by far the most sensitive components. In my planning, I foresee appropriate protective measures here.
These also need to be checked/inspected. However, this can be carried out by a reasonably skilled operator without the need for a professional tradesperson.
ostsee schrieb:Hopefully after precise sizing and calculation, otherwise it can quickly turn into a money pit.
...we are planning to install a ground source heat pump.
ostsee schrieb:Yes, brine inspection is required. The intervals for this are specified/determined by the responsible local water authorities. The building owner is responsible!
...Does the chimney sweep or anyone else regularly come by to inspect the system?
ostsee schrieb:
...I hope that our general contractor calculates the sizing correctly... Whether hope is sufficient here, I would seriously doubt based on my experience. Heat pumps are among the most sensitive heat generators. High energy efficiency in operation is only achievable if everything fits!
There is often a significant gap between the energy-saving regulations/KfW certification on paper and the solution actually implemented. This results in higher operating costs!
ostsee schrieb:
...What should I watch out for here or where can I possibly keep an eye on them? It starts quite simply at the point when a general contractor/main contractor proposes or offers a specific manufacturer/device.
Accurate sizing is only possible if all necessary calculations have been done in advance.
At this stage, you can request all documents and have them reviewed. If they are not available, you know what your hope is based on and its value 😉
Since 2009, with a properly worded specialist contractor declaration, the client also has better legal protection in case of subsequent issues.
Furthermore, ask for a consumption forecast for heating and domestic hot water and have it reviewed externally. This is where you can separate the wheat from the chaff.
In independent planning, this should actually be standard. However, general contractors/main contractors often forget this or simply do not know how. 😉
One more question regarding this topic.
The general contractor (GC) has provided the following description:
Heating heat pump with a heating capacity of 7-10 kW as the heat source. Instead of the 120-liter (32-gallon) tank, a storage tank with approximately 180 liters (48 gallons), integrated into a compact unit, is connected to the heat pump for domestic hot water supply.
To ensure the minimum circulation volume, a 120-liter (32-gallon) buffer tank is integrated into the system.
Why is a buffer tank still necessary? The GC could not explain this to me clearly.
ostsee schrieb:
...To ensure the minimum circulation volume, a 120-liter (32-gallon) buffer tank is integrated into the system. A very clear sign that hardly any calculation or optimization for the heat pump was done here! :o ostsee schrieb:
...Why is a buffer tank still needed? The general contractor couldn’t explain that clearly to me. This shows there are significant shortcomings regarding the heating system. A buffer tank (what type?) for the heating system is usually completely unnecessary or even reduces the system’s efficiency. Only in exceptional cases is it required. This results from the calculations, if they were actually performed.
Best regards.
