ᐅ The patio window with door has a slight gap near the tile.
Created on: 30 Oct 2018 14:15
Kaspatoo
Kaspatoo30 Oct 2018 14:15
Hi,
We have a large window with a door leading from the living room to the terrace.
Recently, I noticed that when I push or pull on the frame, a small gap appears between the window frame and the silicone seal where it meets the tiles.
Is this normal, or is something wrong?
Here are a few pictures of my "pushing".
Close-up of a wood-look floor tile next to the door hinge and glass jug
Close-up of a wood or laminate floor with joints next to the door frame
30 Oct 2018 15:21
It has come loose, yes. But that’s not a problem since the silicone joint is only for aesthetic purposes.
How old is the house?
Silicone joints tend to separate during the drying process of the screed and need to be replaced. It’s possible that they’re starting to crack little by little in your case. This is not covered by the warranty; it should also be stated somewhere in your documents that silicone joints are excluded.
Many builders already point this out in advance and offer to install the joints only after one to two years.
Kaspatoo30 Oct 2018 21:12
The house is one year old.
I am not sure if the silicone sealant has come loose.
My main concern was actually that I can move the window frame back and forth so much.
Bookstar
30 Oct 2018 21:14
Since it has to be screwed in, I think nothing should move there.
Kaspatoo1 Nov 2018 10:41
Bookstar schrieb:
Since it has to be screwed on, I think nothing should move there.
Yes, that was my thought as well. Should it be completely rigid, or is a bit of play allowed?
