Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
11ant11 Sep 2018 15:35
kaho674 schrieb:
But is it also "grippy"? I don't really like it when the metal cuts into the flesh.
When gripping lightly under normal conditions, no, maybe if you fall? ;-(
truce11 Sep 2018 15:57
While we’re on the topic of stairs:
Here is our staircase after completion.
Type:
Concrete staircase built by the local mason, with a granite finish sourced from the natural stone factory.
Two photos were taken in daylight, and one photo was taken in the evening with stair lighting.
Modern indoor staircase with gray steps against a white wall; wooden dresser with blue cushions.
View from above of a modern gray indoor staircase; window on the left with a plant on the windowsill.
Gray indoor steps with a wooden bench and gray cushion along the wall.
11ant11 Sep 2018 16:06
... and how has it changed since then?
Bookstar
11 Sep 2018 16:09
What I like is that the baseboard on the wall side is plastered flush. I think that’s great! Just out of curiosity, how is that done?
truce11 Sep 2018 16:15
Bookstar schrieb:
What I like is that the base on the wall side is plastered and flush. I think that's great! Just out of interest, how is that done?
The plasterer applied plaster up to about 20mm (3/4 inch) below the finished top (FT) of the concrete stair treads and left the rest exposed.
We used this approach throughout the house wherever tiling was done (in the bathrooms, utility room, and pantry).
First, the tiling was completed, then the plaster was applied ("troweled on"), followed by a final finish coat. Of course, the floor coverings and stairs were carefully masked off each time.
All done by ourselves.
11ant11 Sep 2018 16:18
Bookstar schrieb:
What I like is that the base of the wall is plastered and flush.
I hadn’t noticed that at all, but I like it too. Sometimes something looks good simply because there’s no mistake.
