ᐅ Anthracite Garage Facing South – Is a Dark Color Problematic?
Created on: 20 Aug 2018 09:56
Grantlhaua
We had to orient our garage to the south and have now learned that dark colors might cause issues here.
Have you had any experience with this?
Aliban201421 Aug 2018 08:48Nordlys schrieb:
Yes, that is correct. Sectional doors made of dark plastic tend to stick then.Are sectional doors from, for example, Hörmann affected as well? I thought they have steel on the outside.
Grantlhaua21 Aug 2018 08:50Aliban2014 schrieb:
Are sectional doors from, for example, Hörmann also affected? I thought they have steel on the outside.Yes, because I started the thread based on a statement from a contractor who installs Hörmann doors.
Aliban201421 Aug 2018 08:57Grantlhaua schrieb:
Yes, I started the thread based on a statement from a contractor who installs Hörmann doors.Thanks for the information.
That is definitely less than ideal.
Our door is planned to be installed with M-ribs and in CH703 color later on. Although we have a roof overhang of 75cm (30 inches) above the garage on the south side, I really didn’t want to have the door painted silver afterward...
That simply wouldn’t match the rest of the house at all...
Aliban2014 schrieb:
Are sectional doors from, for example, Hörmann also affected? I thought they have steel on the outside. We are basically talking about double-walled, foam-filled metal panels.
In my view, it is important to ensure that the sections are not too large and that each section is reinforced with a profile. The user in the aforementioned forum did not take either of these points into account.
With three manufacturers, I was only able to get stiffening profiles installed after specifically requesting them. Even Hörmann and Novoferm only offered this upon my explicit request.
Other manufacturers, who do not rely as much on their brand name, do this automatically for door widths of around 5.6m (18 feet), regardless of the color choice.
