ᐅ Insulating the Garage Roof – Roof Sealed with Bitumen Membrane
Created on: 15 Aug 2018 19:30
Bauherr_0877
Bauherr_0877
15 Aug 2018 19:30
Our house dates back to 1962, and the garage roof expands slightly due to heat from the sun in summer. This causes cracks in the walls and prevents us from plastering the walls.
I want to protect the roof from the heat (sun) and am looking for ideas.
Currently, I am considering two options: either protecting it with gravel or, more complex and expensive, with a green roof for the garage.
Does anyone have other ideas or experience with these two options?
At the moment, the roof is sealed with roofing felt.
Thank you very much
Müllerin
15 Aug 2018 21:33
No matter what you do, do you have a structural calculation for the garage? You don’t want the roof to collapse...
We will be installing an extensive green roof, using sedum and a few grasses, and have a reinforced concrete slab...
O
Otus11
15 Aug 2018 22:56
Even with our green-roof garage featuring a wooden beam ceiling, the structure and slope (4%) have been reinforced.
Insulation without heating causes condensation.
Alex85
15 Aug 2018 23:36
Otus11 schrieb:
Even for our green roof garage with a wooden beam ceiling, both the structure and the slope (4%) have been reinforced.
May I ask about the material thicknesses?
O
Otus11
17 Aug 2018 10:43
Beams are 28cm (11 inches) high x 10cm (4 inches) wide, plus additional sloping layers on top, for a size of 9 x 6 meters (30 x 20 feet).
The beams were also spaced closer together.
niri09
17 Aug 2018 10:53
Müllerin schrieb:
we will use extensive green roofing with sedum and a few grasses, and we have a reinforced concrete slab...
Are you doing it yourselves or hiring someone? Due to our development plan, our garage must also have green roofing. It looked so easy on YouTube. But the garage supplier charges 800-900 € for a single garage.
