ᐅ Are roller shutters possible for large lift-and-slide doors?
Created on: 12 Aug 2018 17:36
E
EinMarc
E
EinMarc
12 Aug 2018 17:36
how is it usually handled with large lift-and-slide doors regarding roller shutters? Is it possible to install standard roller shutters even for, for example, a 6m (20 feet) wide window area?
Marc
F
FundS
12 Aug 2018 17:54
Roller shutters can only be installed up to a certain width. At 6m (20 feet), this will most likely require two roller shutters.
Müllerin
12 Aug 2018 18:00
3rd result on Google, a roller shutter manufacturer, mentions a maximum width of 6m (20 feet). However, I didn’t quickly check whether this applies to electric shutters or not, or which materials are involved.
F
FundS
12 Aug 2018 18:06
Müllerin schrieb:
whether that will be for electric or not
With a width like that, I would definitely go for electric roller shutters. Otherwise, it would be impossible to raise them manually.
E
EinMarc
12 Aug 2018 18:17
Two roller shutters wouldn’t be a problem if they can be installed on continuous window fronts like these, right?
But that’s exactly where I lack knowledge and have doubts. Where are the roller shutters supposed to be guided if it’s a sliding door? That’s what I actually meant.
F
FundS
12 Aug 2018 18:26
Is this a 6m (20 feet) lift-and-slide door? So, 3m (10 feet) fixed panel and 3m (10 feet) movable sliding door?
