Created on: 2 Oct 2017 23:25
R.Hotzenplotz
Hello everyone!
Alex85 schrieb:
Dear 11ant, please drop the doomsaying. You can clearly see how much pressure the thief is under. So why do you keep betting on that?
I think it’s ultimately all about appearance. Especially the box in the kitchen can be integrated, maybe with a panel from the kitchen manufacturer in front of it, and the corner wall cabinet could simply be 70cm (28 inches) wide instead of 90cm (35 inches).
Of course, it’s not perfect, but nobody sells a house because of a minor visual flaw. How absurd is that. I completely agree!
R.Hotzenplotz10 Jul 2018 08:52I can now come to terms with a solution like this one.
But it should be at the same level as the cabinet. Something like this:
I just don’t know if that’s even possible, since the lights are planned with halogen boxes in the drywall ceiling. I’ve contacted the lighting designer to ask if they can simply be lowered or how that would work?
R.Hotzenplotz schrieb:
So, I’ve had two inspectors come by, and both criticized the base waterproofing. They both said there’s a reason why there is a DIN standard for it and that the implementation does not comply with the recognized rules of technology.
Tomorrow, I will post the full report here.How would the base be waterproofed in your projects? Don’t you have a site manager? Usually, they are responsible for ensuring proper execution according to the DIN standard.
Sabine
R.Hotzenplotz10 Jul 2018 09:34Curly schrieb:
How is the base of the foundation waterproofed in your case? Don’t you have a site manager? Normally, they take care of ensuring the work complies with DIN standards.I will post the report later as soon as it is available. This was already explained somewhere in this thread by the first expert.
Yes, we do have a site manager. But as you can see from this thread, not everything is ideal, and the site manager admits that he deviated from the DIN standard. However, he claims it was faster and, in his view, equally effective.
