ᐅ Floor area ratio; Section 19, Paragraph 4 of the land use ordinance – Any experiences?
Created on: 29 Jun 2018 11:56
Garlintor
Garlintor
29 Jun 2018 11:56
I have a few questions regarding Section 19, Paragraph 4 of the Land Use Ordinance.
[Facts:]
Plot size = 554.6 m² (5972 ft²)
Floor area ratio = 0.3
Buildable area = 166.38 m² (1792 ft²)
[My understanding of Section 19, Paragraph 4 of the Land Use Ordinance:]
Floor area ratio = 0.3 + 0.15 (50% of the specified floor area ratio) = 0.45
Buildable area = 249.57 m² (2686 ft²)
Is my understanding correct?
Which areas are included in this calculation?
Does Section 19, Paragraph 4 of the Land Use Ordinance have to be specifically mentioned in the zoning plan (building permit / planning permission) to be applied, or is it always applicable?
Or am I completely wrong?
Site plan of a development area: streets, building areas, green spaces; north at top, red circle marked
Image showing legal text on type of land use and residential area regulations in construction
Scan of building regulation document about garages and accessory buildings with paragraphs.
Excerpt from Section 10 and Section 11 of Building Code: surface drainage and compensation measures.
Document with regulations on roofs, roof covering, and building envelope
11ant29 Jun 2018 12:28
Your land use plan states everything about the floor area ratio in §3. The municipality does not have to apply a 50% "additional factor" for garages and driveways; I find the regulation here, including the provision for cul-de-sac plots, exemplary.
Garlintor schrieb:
Or is my idea complete nonsense?
By the way, the "additional factor" is purpose-specific; any driveway area not used cannot be added to the house. In this respect, your idea (of casually adding up areas) is indeed nonsense.
Garlintor
29 Jun 2018 12:36
Thank you for your reply
Your zoning plan states everything about the floor area ratio in §3.
So is my "calculation" nonsense?! Since § 19 para. 4 of the Land Use Ordinance is not mentioned...
Garlintor schrieb:
Facts:
Plot size = 554.6m² (5967 sq ft)
buildable area = 166.38m² (1792 sq ft)
Is that then "correct"?
11ant29 Jun 2018 12:43
You have correctly applied the factor of 0.3. If the land-use ordinance replaced zoning plans, there would be no need for zoning plans. Therefore, it is cited as a basis only where its regulations are adopted unchanged. However, in this case, more advanced considerations have been commendably made.
Depending on the federal state, roof overhangs, bay windows, etc., may also be included in the floor area ratio. It is therefore not advisable to exhaust it solely with the foundation slab. Moreover, when a floor space index is specified, both values apply as maximum limits. So you also need to consider your floor space index of 0.45. Thus, despite the possibility of two full stories, the floor space index of 0.45 still applies. Roughly estimated, you should keep the footprint under 155 m² (1,670 sq ft).
Denis L.
29 Jun 2018 13:30
Garlintor schrieb:
So, is my "calculation" nonsense?! Since § 19 paragraph 4 of the land use ordinance is not mentioned...
Yes, the calculation is incorrect.
For the main building, a maximum built-up area of 166.38 m² (1,791.6 sq ft) is allowed.*
For garages etc., you may exceed this limit by up to 0.15 * 166.38 = 24.95 m² (268.5 sq ft).
*As 11ant already mentioned, you should not fully use this allowance but rather rely on the specifications in the "house fact sheets."
11ant29 Jun 2018 13:45
Denis L. schrieb:
For the main building, a maximum built-up area of 166.38m² (1790 sq ft) is permitted.*
No, and I even have to retract my statement
Roughly, you should keep the floor area under 155m² (1668 sq ft).
The floor area ratio does not apply only to the main building here; an exemption allowing an exceedance is granted exclusively to the “Pfeifenkopf” plots (and even there, explicitly only concerning the access way).
Denis L. schrieb:
For garages etc., you may exceed this limit by a maximum of 0.15*166.38 = 24.95m² (268.5 sq ft).
Where do you get this (also unusual) 15% allowance from?
