ᐅ Plastic windows cracking due to sunlight and thermal expansion
Created on: 19 Feb 2018 09:15
Z
zimmer2110
Z
zimmer2110
19 Feb 2018 09:15
I have the following problem with a newly built house (Dec. 2015) featuring the triple-glazed plastic windows listed below. Whenever the sun comes out (whether in winter at 6°C (43°F) outside temperature or in summer at 30°C (86°F)) the windows or window frames start making cracking noises. Strangely, only the windows on the south side (sunrise side) are affected.
The cracking noise can be heard quite loudly at intervals of about 30 seconds to one minute during the worst phases (sometimes the cracking is audible for several hours daily – usually until the sun reaches its highest point above the house at midday). It sounds like small popping noises. At times, the noise is so loud and frequent that sleeping during summer from around 7:00 a.m. is no longer possible.
So it definitely has to do with heat and expansion.
The issue was reported to the home builder in May 2016, who then passed the problem on to the subcontractor. So far, only the following measures have been taken:
1. Slightly enlarged (ventilation) drill holes in the frame
2. Shortened seals
3. Screws tightened and loosened
4. Screws completely removed
All attempts so far have been unsuccessful. I have found only a few forum posts on this issue, and unfortunately, no homeowner has ultimately reported a solution. I have read about some approaches.
Since this has been ongoing for almost two years and the building companies are now more or less refusing to try further measures, I am forced to involve a lawyer.
Manufacturer details:
Plastic windows:
Central seal S 9000 | IKD up to Uw W/m²K 0.72* (6016/6003/84)
Color scheme with Acrylcolor (base body and color permanently fused) inside white and outside RAL 7016 (anthracite)
The triple-glazed windows are fitted with insulating glass containing a "SWISSPACER". Ug from 0.5 W/m²K depending on profile thickness, g-value 53%.
Structure and properties:
1) High-tech coating for better light and heat transmission
2) Gas filling in the space between panes
3) Ideal glass spacing of 15 or 16 mm (0.6 or 0.63 inches)
4) Excellent optical properties
Attached is an image showing the window construction.
Do you have any further suggestions for solutions? In particular, I’m interested in how others affected have dealt with this and what the current status is. What are the chances of success when involving a lawyer or expert? I understand that windows can make some noise and that this is not automatically a defect. However, constant and loud cracking due to sunlight is, to me, not acceptable.
Thank you very much for any information, help, or feedback!
Querschnitt eines Mehrkammerfensters mit 84 mm × 83 mm Abmessungen und Uw-Wert 0,72 W/m²K
tomtom7919 Feb 2018 09:21
Since plastic and glass expand differently, I would say the rubber seal is under too much pressure. Have you tried lubricating it? Especially everywhere the sealing rubber touches the glass.
Z
zimmer2110
19 Feb 2018 11:46
I rather have the impression that the windows are wedged in too tightly!? Attached is a photo.
Exterior view: Large blue window frames, glass facade on white building wall.
tomtom7919 Feb 2018 12:17
Why is there almost no gap between the roller shutter and the window frame? Is that normal?
And with dark windows, unfortunately, no one will be able to help you; everyone will say it is normal. Still, try to ease the movement by applying silicone or grease.
Z
zimmer2110
15 May 2018 09:03
The cause seems to have been found by now. As soon as the sun shines on the roller shutter tracks, the "window"/"frame" starts to crack. The roller shutter track is made of aluminum and screwed onto the plastic frame.
As a temporary solution, a white metal cover was placed over the anthracite-colored roller shutter track, which reduced the cracking. With the white cover, it cracks 1-2 times every 30 minutes; without the cover, 20-30 times every 30 minutes.
However, with 5 windows, it still cracks quite often.
tomtom7915 May 2018 09:07
Our rail is not connected to the window—why is it in your case?
