ᐅ Floor plan design for a hillside house with 5 children's bedrooms
Created on: 17 Jun 2017 12:31
Arifas
Dear fellow contributors,
I’m sharing our first attempt at the floor plan. Unfortunately, I can’t fill out the list because copying it over on my phone doesn’t work properly, sorry.
Key data:
5 children between 0 and 11 years old
2 adults in their mid-thirties
Plot of about 900 sqm (9700 sq ft), facing north
Building window edge on the street side: 17.35 m (57 ft)
Sloped site; within the building window, the ground rises about 2 m (7 ft) over 10 m (33 ft) from front to back
We want 5 small children’s bedrooms, a slightly larger office for working from home, a master bedroom, three showers, three toilets, a bathtub, and access to the garden through the living room on the upper floor. One wall in the children’s rooms should be removable later.
The attic is walkable.
We are allowed to build 2 full stories, with a ridge height of about 12 m (39 ft) and an eave height of 11.6 m (38 ft).
We would prefer a hip roof.
The current drawing is 9.5 by 11 m (31 by 36 ft), but we would like to have around 195 to 205 sqm (2100 to 2200 sq ft) of living space later; garage or storage will be added.
The back wall of the house is embedded up to about 2 m (7 ft) into the slope.
I will try to attach a rough overview of the plot.
Handgezeichnetes Grundriss-Skizzenblatt mit Raumaufteilung und Beschriftungen
OG-Grundriss: Terrasse oben, Sofa, Küche, Essen, Kamin, HWR, Bad, Kind 4, Treppe
Arifas1 Mar 2018 21:56
On Monday, construction is actually supposed to start *squee* [emoji23]. I had almost given up hope [emoji85][emoji13][emoji1]. But according to the groundworker, it will begin on Monday, and the excavator will probably arrive tomorrow. Incredible. And then we’ll finally have a hole in the plot [emoji126][emoji445][emoji41]. At 8 a.m. on Monday, the surveyor still needs to quickly check the site, and then it really gets going [emoji4].
Arifas8 Mar 2018 16:48
Earthworks were almost completed today, the utility providers were on site, tomorrow the trenches will be dug, and the gravel has already been laid. Tomorrow, the plate load test will take place. Next week will be the fine staking, and if all goes well with the external building surveyor, the foundation slab will be poured next Friday [emoji126]. I think things are going well [emoji106].
Arifas8 Mar 2018 16:50
This is from this morning. Since then, quite a bit has happened again.
Construction site with piles of gravel and crushed stone, earth embankment, houses, and trees in the background.
kaho6748 Mar 2018 19:46
Yippee. A hole filled with gravel.
haydee
8 Mar 2018 20:36
You can move over to the house pictures thread.
Now it’s working.
Arifas8 Mar 2018 21:05
haydee schrieb:
You can move to the house pictures thread.
Now it’s happening.
So, completely without a house [emoji23]?!
But at least it’s not floor plan design anymore.
I find it amazing how fast things are moving now.
