ᐅ Issues with the installation alignment of our planned solar power system
Created on: 1 Feb 2018 21:10
Lobster
Good evening,
Our building permit / planning permission has already been approved, and the final planning is underway.
Now we have a problem with the solar system for domestic hot water.
The roof ridge runs almost exactly from north to south. This means we only have space on the east and west sides of the roof. The energy consultant ran the calculations and concluded that neither side provides enough capacity to meet all requirements.
Simply rotating the house is not an option, and of course, we had a reason for placing it as we did. However, we did not anticipate these issues.
One initial idea was to install the system on the carport roof at home. However, this is not directly attached to the house, so a distance of about 6–10 meters (20–33 feet) would need to be bridged to the utility room.
Does anyone have experience or ideas? We would really appreciate it.
Mastermind12 Feb 2018 21:47wrobel schrieb:
What Mycraft described is correct.
Increasing the storage volume, for example to 300 liters (80 gallons), only marginally improves the solar coverage ratio.
Therefore, and to keep systems as compact as possible, manufacturers often offer 200-liter (53 gallons) tanks for single-family homes.
I was quite surprised, though, because in a recent discussion I was told that heating systems should be as inexpensive as possible to purchase.
In this context, a domestic hot water heat pump combined with photovoltaic panels is recommended without objection.
It’s not about biomass here, where you can certainly invest more money.
OlliUnfortunately, solar thermal systems are often sold by developers at a high price and installed poorly from a technical standpoint... You realize this when suitable protective measures don’t work because there is too much hot water in summer, or when the circulation is so bad that the pipes are pushed to their limits... In the end, after just a few years (barely outlasting the warranty), the system fails. Then it becomes a money pit.
I’m simply assuming there is no heating load calculation, since the heating system (gas/oil) is wildly oversized.
The explanation for this: "We always install that..."
P.S. A domestic hot water heat pump works fine without photovoltaic panels.
However, photovoltaic makes even more sense in this case.
By the way, photovoltaic essentially pays for itself.
Solar thermal saves a bit on hot water costs for the conventional heating system.
Photovoltaics save electricity and even bring in money when there is surplus... But beware: this involves a bit of paperwork (tax office/distribution network operator...).
Mastermind12 Feb 2018 22:10I am interested in the costs for solar thermal systems.
A domestic hot water heat pump without installation and with an integrated 300-liter (80-gallon) storage tank can be purchased for about 1,500 to 2,500 euros. (Brands like Stiebel Eltron, Weishaupt, Feinwerk, novelan, Viessmann, etc.) The installation effort including transport typically takes less than half a day with two workers.
I am simply assuming that the builder charges almost 1,000 euros for the 280-300 liter (74-80 gallon) hot water storage tank alone. The solar thermal panels cost around 3,000 euros, and the installation likely takes 1 to 2 days with two workers.
I only know what the plumber charged for our entire house: 17,000 gross. For that, he provided a Junkers gas boiler, underfloor heating for 108 sqm (1160 sq ft) of living space, solar thermal for hot water with a storage tank, bathroom with two sinks and two toilets, all Duravit with Grohe fittings, matching shower set, a Helios exhaust fan with humidity control, electric towel radiator, two outdoor taps, utility sink, washing machine connection with angle valve, dishwasher connection, and kitchen connections.
So, the solar system can't be that expensive.
