ᐅ The windows on the roof terrace are installed in an unusual way.
Created on: 28 Jan 2018 17:48
I
Instabil
I have a question.
Are the windows/doors on our roof terrace installed correctly?
They were initially fully installed but were later pulled out like this.
It looks very makeshift to me.
No, only plaster will be applied afterwards, no additional insulation.
The brown substance is waterproof slurry, which we started applying today as a precaution because during the last rain moisture came straight through.
I have a question.
Half of the window is sticking out??? I don’t understand why your building inspector has no opinion at all. Even without experience, they should at least have or pretend to have an opinion. Our energy consultant wants photos of the window installation. Maybe your energy consultant has an opinion?
Zaba12 schrieb:
The window is sticking out halfway??? I don’t understand why your building supervisor doesn’t have any opinion at all. Even without experience, he should at least have or pretend to have an opinion. Our energy consultant wants photos of the window installation. Maybe your energy consultant has an opinion?Exactly. It is sticking out. Let’s see who was responsible. We never dealt with them personally.B
Bieber081529 Jan 2018 07:34Instabil schrieb:
The brown substance is sealing slurry, which we started applying today as a precaution because the last rain caused moisture to pass through directly.Normally (if you have a construction contract) it is not advisable to do the work yourself. It’s better to file a defect report!ruppsn schrieb:
Execution planning -> detailed design. You really don’t have a detailed design? That sounds unusual...Our developer built without it. In the end, it wasn’t as bad as you might expect (as long as you stick to the “developer’s standard”).Bieber0815 schrieb:
Normally (when you have a fixed-price contract), it’s not advisable to do the work yourself. It’s better to submit a defect report!
Our general contractor built without following the proper procedures. It wasn’t as bad as one might think (as long as you stick to the "contractor standard").Since June last year, we have pointed out these exact issues—that the structural builder did not complete the waterproofing—and since the end of September about the windows... without any response!
Yesterday, we applied waterproof slurry to the entire base area, up to above the backfill line, and also to the top of the windows, after consulting with the plasterer, who approved the solution.
There are plenty of defect reports, but no reaction! Deadlines are also being ignored.
Bieber081529 Jan 2018 09:53Instabil schrieb:
There are plenty of defect notifications, but no response! Deadlines are also ignored. Knowing your rights and actually enforcing them are two different things. The best approach is usually, in order, good communication and legal action (specialized construction lawyer). Then the question arises: Is it better to have a painful end than a never-ending problem? In other words, if the contractor fails to meet their obligations, this may justify terminating the contract for work. Again: of course, only with legal support.
