ᐅ Practical size for windows and roller shutters (or blinds)
Created on: 6 Jan 2018 17:17
Thomas1980
Thomas1980
6 Jan 2018 17:17
Good evening,
We are currently planning two fairly large patio doors in our living area.
1.: Height: 2.55 m (8 ft 4 in) Width: 3.20 m (10 ft 6 in)
2.: Height: 2.55 m (8 ft 4 in) Width: 2.40 m (7 ft 10 in)
The plan includes a built-in roller shutter box with a height of 25 cm (10 inches). Flush ceiling lintels are planned in the concrete ceiling. The floor construction measures 20 cm (8 inches). The rough construction height is 3 meters (9 ft 10 in) (from the top of the raw floor to the underside of the ceiling).
The height is composed as follows:
- 20 cm (8 inches) leveling element for screed due to floor construction up to the finished floor surface
- 2.55 m (8 ft 4 in) window/door height
- 25 cm (10 inches) built-in roller shutter box
= 3 m (9 ft 10 in)
My question to the experts: Should I reduce the width of the openings to avoid problems with the roller shutters? For example, instead of 3.20 m (10 ft 6 in), make it 3 meters (9 ft 10 in)?
The other windows in the building are planned by the architect with a width/rough opening of 1.60 m (5 ft 3 in) (double windows).
Thanks and regards
Alex85
6 Jan 2018 17:59
Do you mean lift-and-slide doors?
Thomas1980
6 Jan 2018 18:05
Yes. The width over 3.20 m (10.5 ft) will have a lift-and-slide door. In the opening with a width of 2.60 m (8.5 ft) there will be a fixed panel plus a standard single-leaf balcony/patio door for opening, approximately 90 cm (35 inches) wide.
11ant6 Jan 2018 19:02
Thomas1980 schrieb:
Should I reduce the width of the openings to avoid issues with the roller shutters? For example, instead of 3.20 meters (10.5 feet), 3 meters (9.8 feet)?
Why—do you think the additional 20 cm (8 inches) would cause a problem with wind load?
Thomas1980
6 Jan 2018 19:15
I’m just concerned that it will be difficult to get a continuous roller shutter box that covers a span of 320cm (126 inches). And a matching roller shutter curtain. I also don’t want it to sag or require a special custom-made solution.
Domski
6 Jan 2018 19:17
For the roller shutters, I would recommend aluminum slats. We have plastic ones at 2.20 meters (7 feet 3 inches) and have already experienced significant bending during storms.
