Hello, my husband and I have the opportunity to purchase a 10-year-old house. The previous owners stated that the monthly gas costs are around 220 EUR per month. The living area is 250 sqm (2,690 sq ft), so it’s quite large. What would be a realistic kW rating for a house of this size?
kW is a unit of power, not energy (kWh)! When buying an existing property, you should always consult a professional to avoid unpleasant surprises.
Best regards.
wondi82 schrieb:Such information should always be regarded with extreme caution, as the user behavior is completely unknown!
Hello, my husband and I have the opportunity to buy a 10-year-old house. The previous owners stated that the monthly gas costs are approximately 220 EUR per month.
wondi82 schrieb:
...The living area is 250 m² (2,690 sq ft), so it’s quite large.
What amount of kW can be considered realistic for this size?
Best regards.
Gissi79 schrieb:
I would get an energy certificate done, or at least check if one exists. But not one based on consumption, rather one based on the building components!Thank you very much for your quick responses! The suggestion about the energy certificate is a good tip; I hadn’t thought of that. We will ask the owners if one is available.
wondi82 schrieb:
...The energy performance certificate is a good tip; I hadn’t thought of that. I will ask the owners if there is one. There is a legal entitlement to this! Make sure it is a consumption-based certificate!
