ᐅ What are solid gypsum boards / drywall panels?
Created on: 12 Dec 2017 14:58
Thomas4711
Thomas4711
12 Dec 2017 14:58
we are currently having a house built and, according to the construction specifications, solid gypsum boards are planned for the non-load-bearing interior walls.
Just to be sure:
a metal stud framework with double layers of gypsum plasterboard (=Image_1, Image_2) is not the same as "solid gypsum boards," right?
Solid gypsum boards = Image_3
Thank you very much & best regards
Thomas
Construction site with metal stud framework of an interior wall in shell construction, drywall work visible
View of unfinished interior of a house with staircase, metal stud wall and cable bundle
Construction worker with safety helmet installing styrofoam wall block in shell construction
toxicmolotof
12 Dec 2017 15:08
1. I have no idea
2. Wikipedia: gypsum wallboard
11ant12 Dec 2017 17:16
Thomas4711 schrieb:
Just to be sure:
A metal stud frame with double layers of drywall (see Image_1, Image_2) is not the same as "solid gypsum boards," right?
Correct guess.
toxicmolotow schrieb:
1. I have no idea
I don’t believe that.
toxicmolotof
12 Dec 2017 21:04
I don't believe that.
Does "I can use Google" count as knowledge?
Thomas4711
12 Dec 2017 21:18
Thank you for the help
11ant13 Dec 2017 00:12
Knowing where to find information is a good starting point. But I meant more that you contribute a significant number of helpful posts, including saying "I don’t know" when you’re unsure about something.
