ᐅ Floor plans that meet all our requirements
Created on: 27 Nov 2017 20:51
chbest
After having approached the topic the wrong way in the last thread, here is another attempt. First, our requirements:
Overall Requirements
The entire project must be completed within a budget of 280,000 euros. The finished product must be a move-in ready house including driveway, carport, lawn, and a hedge around the property.
Requirements for All Rooms
Every room must have a window.
Requirements for Children’s Rooms
The children’s rooms must be at least 10 m² (108 sq ft) in size.
The children’s rooms should preferably be square-shaped.
There must be three children’s rooms included.
Preferably, there should be four children’s rooms included.
Requirements for Kitchen, Dining, and Living Rooms
The kitchen must have at least one wall without a door measuring 230 cm (7 ft 7 in) and an adjacent wall without a door measuring 310 cm (10 ft 2 in).
The floor plan should include an open-plan kitchen-living area.
The kitchen and dining room can be in direct view of each other.
The living room should not be visible from the kitchen but should be visible from the dining room.
(An ideal solution would be an L-shape layout with the kitchen at one end and the living room at the other.)
Requirements for the (Master) Bedroom
The bedroom must be able to accommodate a wardrobe 200 cm (6 ft 7 in) wide and a bed 180 cm (6 ft) wide.
The bedroom may have space for a nightstand on each side of the bed.
Requirements for Bathrooms
There must be two bathrooms, both equipped with toilets.
One bathroom must include a bathtub.
Pantry / Storage Room
The home must provide at least 4 m² (43 sq ft) of storage space.
Utility Room
The utility room must have space for a washing machine and a dryer.
Plot size
Approximately 300 m² (0.07 acres)
Slope
No
Floor area ratio (FAR)
0.4
Gross floor area ratio
0.8
Building envelope, building line, and boundaries
Edge development
Number of parking spaces
Two
Roof shape
Architectural style
Orientation
15° roof direction
Maximum heights / limits
FH 11.5 m (37 ft 9 in); TH 6.5 m (21 ft 4 in)
Other specifications
Homeowner requirements
Building type
Solid construction house, bungalow
Basement, storeys
Only one ground floor level
Number of occupants, age
Two adults and one preschool child, with tendency to increase
Space requirements on ground and upper floors
Family use or not necessary
Number of overnight guests per year
About 40
Open or closed architecture
Conservative or modern building style
Open kitchen, kitchen island
Open-plan kitchen-living area
Number of dining seats
3+
Fireplace
Yes, mine
Music / stereo wall
No, but a 5+1 surround sound system with a 280 x 158 cm (110 x 62 in) screen should be planned.
Balcony, roof terrace
No
Garage, carport
Carport and bicycle shed
Utility garden, greenhouse
No
Additional wishes / special features / daily routine, also with reasons
If possible, barrier-free design so the house can serve as a residence for old age
General House Design
Who designed it
Planner from a construction company
Personal price limit for house, including fittings
280,000 €
Preferred heating technology
Gas heating
Specific House Designs
Design number 1 - Park 140 W
Two-storey floor plan: Ground floor with living room, kitchen, hallway, WC; upper floor with 4 rooms and bathroom.
Central living area where family life happens. Kitchen, dining, and living rooms are ideally arranged in an L-shape.
Windows in every room for good ventilation and natural light.
Five equally sized rooms that can be used flexibly.
What do you not like? Why?
Quite a few doors on the left side of the plan, making that area feel busy.
Estimated cost according to architect/planner
163,400 €
Which details / expansions can you do without?
Which details / expansions are absolutely necessary?
Why does the design look the way it does now?
Standard design from the planner
Design number 2 - Bungalow 123
Floor plan Bungalow 123: Living, dining, kitchen, master bedroom, child 1, child 2, office, hallway
Windows in every room for good ventilation and daylight.
Guest toilet is easily accessible from the center.
Two showers.
The large bathroom is only accessible through the master bedroom.
Only three children’s rooms.
The children’s rooms vary in size.
xxx €
The master bedroom is too large.
Design number 3 - Bungalow 119
Floor plan Bungalow 119: Living and dining area, kitchen, bathroom, master bedroom, children’s room, technical room
Guest toilet is easily accessible.
Two showers.
A terrace in the bottom right of the plan has abundant sunlight during the day.
xxx €
Pumbaa
27 Nov 2017 21:57
chbest schrieb:
Thanks for the note. The plot size for bungalows must be at least 372.5 m² (around 4,010 ft²).
Plus the area you need for terrace, garage, pathways, etc. That also counts toward the floor area ratio – usually at least.
chbest
27 Nov 2017 22:07
Pumbaa schrieb:
Plus what you need for the terrace, garage, paths, etc. That also counts towards the floor area ratio—at least usually.
Oh, I wasn’t aware of that either. Then it definitely won’t be a bungalow. At the moment I’m still looking for smart 120 m² (1,292 sq ft) floor plans. They should also be feasible as a single-family house within our budget.
chbest
27 Nov 2017 22:26
Now I have found a floor plan that we both really like. It is the Bravour 130.
Two-story house floor plan: Ground floor with kitchen, dining, and living area; upper floor with bedrooms and bathroom.
It has exactly the rooms we want. It features the L-shape that we like so much. Hopefully, there is some storage space in the attic.
Unfortunately, the house costs 241,000 € (about 260,000 USD) from the supplier, which is well above our budget. But it is an idea that we can definitely present to a local builder.
kbt09
28 Nov 2017 06:05
That would be a full floor as the upper floor, so the rooms function properly.
The technical room and utility/storage room are missing.
For open-plan living areas, I would generally place the kitchen/dining area facing the terrace and position the sofa and TV in the quieter corner.
E
Evolith
28 Nov 2017 08:17
So a budget of €280,000 (about $300,000) for a house built to your specifications will be quite tight (outdoor installations not included).
3 children's rooms --> 10 m² (108 sq ft) is really on the small side. We have rooms of 12 and 11 m² (129 and 118 sq ft), which I find just barely sufficient. Smaller is possible but arranging furniture will become very cramped.
Bedroom --> 14 m² (151 sq ft) is not too large, I can already tell you that. Our bedroom is 16 m² (172 sq ft). With a large wardrobe, a 2-meter (6.6 feet) bed, and a small dresser, space feels tight. Especially with a square room layout, you end up with very little space between the bed and the wardrobe.
Storage room --> you either plan a basement or at least a separate technical room of around 8 m² (86 sq ft). The heating system and connections need to go somewhere.
28 Nov 2017 08:29
In this case, the utility room is probably intended to be the study.
... a floor plan that every home builder offers. Only most floor plans are designed for two children's bedrooms. If you reduce the size of the rooms in such designs on the upper floor, you can also fit three small bedrooms for children.
