The last utility provider (electricity) has now completed the house connection for me. They extended the underground cable and pulled it into the house.
When I asked if the underground cable should be further protected with a conduit, they said it wasn’t necessary. I was advised to backfill the cables with sand and then refill the trench normally with gravel.
Only the water company wrapped their PE pipe with a cheap corrugated pipe.
Is this no longer necessary nowadays? The cables and pipes that come directly from the ground into the trench aren’t even surrounded by sand.
I’m a bit worried about closing the trench like this, in case a pipe gets damaged later and everything has to be dug up again.
Bau-Schmidt5 Nov 2017 14:45The answer is a stone-free base. That’s all you need nowadays.
Kusserob schrieb:
backfill with sandThat is the key point... nothing more is needed.
I also have a question about this.
Do you all use these expensive utility connections to protect the entry points against water, or is there a more affordable solution?
