ᐅ Walls in the shell construction stage already affected by moss growth
Created on: 29 Oct 2017 22:58
I
Instabil
I
Instabil
29 Oct 2017 22:58
We are currently, unfortunately still, in the shell construction phase and noticed during our last site visit that a wall, as shown in the pictures, is so wet because water is running down from the un-drained roof terrace that the wall on the first floor already has moss growth.
Is there a way to dry this wall quickly so that the plasterer can start soon?
Explanation:
The roof terrace on the second floor currently has no drainage apart from the outlet where water runs directly along the exterior wall; it was simply forgotten... as was the insulation of the roof terrace, which luckily we as the clients noticed in time.
The missing drainage only became apparent to us after the walls had already been built.
In the meantime, pipes have been laid in the floor for the drainage of the roof terrace, but the general contractor is ignoring the other issues.
What options do we have to dry the wall quickly, properly, and effectively?
Interior shell construction: untreated concrete block wall construction in a corner
Construction site interior with window, unplastered walls, and visible water pipes.
toxicmolotof
30 Oct 2017 08:10
None?
The water must be directed away from the wall on the outside, no matter what. Otherwise, you can dry the interior as much as you want.
First address the cause, then the symptoms.
Can you connect something to the drainage at the top? A PVC elbow/pipe and route it away from the building.
But why do you want to dry the wall? Plastering will introduce more water into your house than it has ever seen before.
What does the house look like from the outside? Is the insulation already attached?
I
Instabil
30 Oct 2017 08:14
There is no external insulation. The Ytong block is 34cm (13.5 inches), if I remember correctly.
The plasterer said that the wall cannot be plastered when it is this wet, as the plaster would otherwise come off.
tomtom7930 Oct 2017 10:21
I
Instabil
30 Oct 2017 10:27
tomtom79 schrieb:
Period? There is only a period there. [emoji849]
11ant30 Oct 2017 12:08
Instabil schrieb:
Period? There is only a period.
That’s enough as a statement after toxicmolotow has already said everything (?).
The missing drainage is not something that can remain absent any longer – this significant defect must be corrected; otherwise, any further steps are pointless.
And don’t forget: document damages with an expert assessment and bill the responsible party properly and within the deadline!
