ᐅ Bathroom half-height tiling. Floor tile used as a shelf on the stud wall.
Created on: 13 Oct 2017 16:13
Malz1902
Malz1902
13 Oct 2017 16:13
We plan to tile our bathroom halfway up, 1.20 meters (4 feet) high. The wall construction in front is 1.20 meters (4 feet) high. The floor tile will be placed on top of this wall as a shelf. The question is whether we should also tile an additional 10 cm (4 inches) on the wall behind it. Our site manager said this would make cleaning easier since you wouldn't be cleaning directly against the wall.
kbt09
13 Oct 2017 16:18
The construction manager is right.
Is that a full frame wall? For example, I only have a frame wall around the toilet and the washbasin next to it. Above the frame wall, the tiling continues up to the point where the edge aligns with the tiles above the washbasin.
Trying to upload pictures: unfortunately, it’s not working.
Badezimmer mit Spiegelwand, Waschbecken, Taschentuchbox und pinkem Handtuch auf Heizkörper
Malz1902
13 Oct 2017 16:37
The pre-wall installation runs entirely through the toilet and sink.
13 Oct 2017 16:42
Malz1902 schrieb:
Our site manager said this would be better for cleaning because you don’t have to reach directly to the wall
Our tiler tried to argue the same with us.
And it’s also nonsense from an aesthetic point of view.
For cleaning, the silicone joint is enough—just wipe it with a cloth using your forefinger. Done.
If you stick another row of tiles above that, you’ll have an edge on top. Comparison: the baseboard (skirting board).
Bau-Schmidt
13 Oct 2017 19:59
If you add a row of tiles on top, you'll have an edge above. Compare it to the baseboard.
This is also present on the other walls with tiles.
14 Oct 2017 00:11
But not where there is a platform!
