ᐅ Cost Comparison for Exterior Walls – Stucco or Wood
Created on: 30 Sep 2017 13:31
Asmus
Asmus
30 Sep 2017 13:31
I am looking for a rough cost comparison between a plaster facade and a timber facade. The focus should be purely on material costs, based on an already insulated solid brick wall. Installation effort, maintenance, costs for scaffolding and labor, etc., should be disregarded.
Unfortunately, I couldn’t find any useful information online :/
Asmus
11ant30 Sep 2017 14:09
Asmus schrieb:
Unfortunately, there is nothing useful available online :/
For some questions, even Deep Thought can only answer "42".
Asmus
30 Sep 2017 16:27
Goodness.... roughly.... I said ROUGHLY
There are countless combinations of both options.
Let’s just try to keep it simple
Plaster: reinforcement plaster with mesh 15mm (0.6 inches) plus basic colored finishing plaster without special properties.
Wood: substructure including fasteners as well as vertically installed standard panels including wood stain
Wind load zone 2
Thank you
Alex85
30 Sep 2017 17:07
It feels like wood/panels as a material would be more expensive. It’s hard to say exactly how much, as it depends on the type of wood.
I also don’t understand why other factors, such as installation effort, shouldn’t be considered, especially since labor costs usually exceed material costs. Even then, I would have assumed wood is more expensive.
You can ask both questions on Wednesday with two quick calls to contractors. Just a rough estimate.
11ant1 Oct 2017 02:11
Asmus schrieb:
Let's just try it simply
Sure: Wood is more expensive. Is that simple enough?
Asmus schrieb:
Plaster: Reinforcing plaster with mesh 15mm (0.6 inches) plus a simple colored finishing plaster without special properties.
Wood: Substructure including fixing materials as well as vertically mounted standard panels including glaze
Wind load zone 2
As you’ve already noticed yourself: Plaster is applied directly onto the wall (plaster = 1x material, onto the wall = 1x labor); wood (1x material) is applied to a substructure (again 1x material) – both involve labor.
So, in total: plaster = 1x material + 1x labor versus wood = 2x material + 2x labor. Assuming – to keep it rough – that labor costs are equal in all compared parts, wood would have to be 1x labor cheaper than plaster in order not to be more expensive overall.
This is logic, it’s a principle. It doesn’t change even at the hundredth decimal place, regardless of the (precise or rough) actual figures.
Clear enough in general?
