ᐅ Where is the best place to install the satellite dish?
Created on: 11 Sep 2017 22:28
Z
zizzi
Z
zizzi
11 Sep 2017 22:28
For a bungalow, where is the best place to install the satellite dish? On the exterior wall or on the roof?
Kind regards
Nordlys
11 Sep 2017 22:34
At my place, the garage has a back wall. If anything comes up, I use a stepping ladder to reach it.
RFR12 Sep 2017 07:52
I installed them on the back wall of the garage because:
Nordlys schrieb:
If something comes up, I can reach it with a step ladder.
dohuli
12 Sep 2017 09:01
It partly depends on the orientation. But generally, I wouldn’t install the satellite dish on the facade, as it simply doesn’t look good.
I would always try to position the satellite dish so that it is as unobtrusive as possible. Often, the best place is on the roof, for example next to a dormer, chimney, or similar. Of course, it’s important to ensure that the dish has a clear line of sight to the satellite.
The argument of "easy access if you need to service it" is secondary in my opinion. If the system is installed properly, you shouldn’t have to touch it for the next 15–20 years.
Bau-Schmidt
12 Sep 2017 09:27
dohuli schrieb:
Either next to a dormer, a chimney, or something similar
The chimney sweep objects to the chimney.
world-e
12 Sep 2017 09:41
The façade has the advantage that it can be installed in an area not susceptible to lightning protection risks, so a lightning current-capable grounding system is not necessary there. On the roof, the situation is completely different.
