ᐅ Is a Bungalow Feasible? What Are the Disadvantages of a Bungalow?
Created on: 3 Sep 2017 19:01
Lisa.M
Lisa.M
3 Sep 2017 19:01
Hello.
We are currently in the process of selecting a plot of land. Originally, we planned to build a two-story house, but as it stands now, it looks like all the plots where this is allowed will be gone. Most likely, we will only be permitted to build a single-story house. Since we are not fond of sloped ceilings, we are now leaning toward a bungalow. The floor area ratio is 0.35, and the plots are between 600 and 700 square meters (about 6458 to 7535 square feet). Would a bungalow with around 140 square meters (about 1507 square feet) plus a terrace and a double garage be feasible? Does the courtyard area count toward the allowed building area? Or would you advise against a bungalow because it is usually much more expensive than a two-story house?
winnetou78
3 Sep 2017 19:36
I think this will be very tight, or it might not fit. Just try calculating it!
Lisa.M
3 Sep 2017 19:43
The question is what exactly is included.
Nordlys
3 Sep 2017 20:00
With a floor area ratio of 0.35, it should be possible. The terrace is included. The garage counts if it is attached to the house. Prefabricated garages placed next to the house are treated like carports. Pay attention to the building envelope. A 140 cm (55 inch) bungalow usually has an L-shape. That should be acceptable. No, it is not significantly more expensive. At least, it shouldn’t be. More foundation slab and bigger roof, but no concrete ceiling, no scaffolding, just simple masonry work. These factors should balance out. Karsten
Lisa.M
3 Sep 2017 20:04
Nordlys schrieb:
With a floor area ratio of 0.35, it should be possible. The terrace is included. The garage counts if it is attached to the house. Prefabricated garages placed separately are treated like carports. Pay attention to the building envelope. A 140cm (55 inches) bungalow usually has an L-shape. That should be allowed as well. No, it is not significantly more expensive. At least it shouldn’t be. More foundation slab, more roof, but no concrete ceiling, no scaffolding, just simple masonry. That should balance out. Karsten
Does the driveway count?
Nordlys
3 Sep 2017 20:06
Here with us, everything you seal. For example, a gravel driveway is not sealed, grass pavers are not, but paving stones are. Karsten
