ᐅ Separate Apartment for Parents: 210 m² Detached Single-Family House with an 80 m² Self-Contained Apartment
Created on: 22 Apr 2017 18:22
schustrik
We are planning to build a house with a separate apartment for parents.
The main house will have two full stories and a hip roof, and to reduce costs a bit, the separate apartment and the garage will have flat roofs.
The house will be built in a new development, and I have already designed the floor plan.
The plot measures 924 m² (11,470 sq ft) and is numbered 30 on the site plan.
Site coverage ratio: 0.4
Floor area ratio: 0.6
Building height: 4.5 - 6.5 meters (15 - 21 feet)
The driveway can only be on the west side because there will be a bus stop on the south side.
What concerns me:
On the upper floor, the east wall runs right above the living and dining area and is actually only supported by the wall between the stairwell and the storage room of the separate apartment. Could this cause any structural issues?
I have drawn the exterior walls as 45 cm (18 inches) thick and the interior walls as 15 cm (6 inches). Load-bearing walls could probably be reduced to 20-22 cm (8-9 inches).
The “wet rooms” like bathrooms and toilets are spread throughout the house, and the separate apartment will have its own heating system. The sewer drainage gullies are located at the south edge of the plot near the bus stop.
Lageplan mit nummerierten Parzellen in Orange/Blau/Grau; grüne Fläche links.
Grundriss eines Wohnhauses mit Eltern-, Kinder- und Ankleidezimmer, Treppe und Heizung.
Grundriss eines Hauses mit farblich markierten Räumen, Möbeln, Terrasse und Garage.
10 Aug 2017 22:43
Amm 22.04. wrote
schustrik schrieb:
We are planning to build a house with a granny flat for our parents.
Floor plan: color-coded rooms (kitchen, living room, office, terrace, garage, sauna)
Floor plan of a house with multiple bedrooms, stairs, furniture, and dimensions.
A few days ago, this came out:
Floor plan of a residential house: central hallway, three children's rooms, master bedroom, beds and wardrobes.
Floor plan of a house with several rooms, yellow exterior areas, furniture, and dimensions.
And honestly: have you ever had a new approach? A different one? Have you ever started to discard your flawed draft, wiped your hard drive, and started over from scratch???
No! To be honest, you have wasted 4 months.
If you continue like this, you won’t need the granny flat anymore.
We could still provide you with lots of new ideas, drawings, and advice. You don’t listen, you don’t read, all good advice just bounces off you.
It’s time for an architect whose eyes must not fall on your drafts!!
10 Aug 2017 22:45
schustrik schrieb:
Here you can see it, a kitchen built into the wall
It is not built into a wall; it just has a panel surrounding it. Nothing more.
kbt09
10 Aug 2017 22:45
Your text doesn’t make clear the desire for a built-in tall cabinet wall.
The question is whether you really need five such cabinets... and in my rough kitchen sketch, I actually meant a so-called Johannes kitchen wall with the cooking area by the window. I am a fan of a sink/preparation island because you spend much less time standing at the cooktop than at the sink and preparation area.
10 Aug 2017 22:47
kbt09 schrieb:
From your text, it’s not clear that the enclosed tall cabinet wall is a specific request.
The question is whether you really need five such cabinets... and in my rough kitchen layout, I was actually referring to a so-called Johanes kitchen wall with the cooking area by the window. I personally prefer a sink/preparation island (you simply spend much less time at the cooktop than at the sink and prep area).
But honestly: that’s just fine-tuning!
Was I even out of this topic already?
Here I am again (once more)
11ant11 Aug 2017 00:49
It's time for an architect who definitely must not see your designs!!
Oh come on, they studied to handle exactly that.
11 Aug 2017 08:03
Oh come on, he studied to handle this.
Unfortunately, many users here confuse the redraw planner with a qualified architect.
