ᐅ LED spot instead of halogen spotlight
Created on: 3 Jul 2017 18:18
ashley
Hello forum, in the ceiling of the new house there are halogen spotlights. The entire wiring is not visible. Behind each spotlight, however, there is a transformer (see picture). Two cables come out of the ceiling at each transformer, each serving as neutral (N) and live (L) – on the other side, the spotlight is connected. If I want to replace the halogen spotlights with LED spotlights, what would I need to do? Is this even possible when only the cables at the openings are visible, or could there be additional electrical installations behind the suspended ceiling that I should be aware of? Can I simply use 220V LED bulbs with the same base and connect them directly to the cables coming from the ceiling?
Thank you and best regards, Ashley
Weißer elektrischer Transformator mit Label auf hellem Gehäuse und Anschlüssen
ashley
6 Jul 2017 08:58
...so could there be technical issues installing 220V spotlights without a transformer there (and with the fittings shown)?
Knallkörper
6 Jul 2017 10:06
Hmm, I don’t see any technical flaw there. I have over 80 spots with 230 V LED bulbs in my house. My wall lamps, stair lighting, and outdoor lighting are also LED and without a transformer.
Regarding the topic: GU5.3 sockets are usually designed for 12 V bulbs. GU10 sockets are typically for 230 V bulbs. The sockets shown in the picture cannot be used for 230 V bulbs.
Both GU5.3 and GU10 bulbs are available with MR16 reflectors (50 mm (2 inches) casing) and can sometimes be swapped. GU5.3 bulbs also come with MR11 reflectors, which are a bit smaller (35 mm (1.4 inches) casing).
Here’s what I would do: remove the transformer, connect a GU10 socket to the cable (99 cents on Amazon), and insert a 230 V LED bulb (e.g., LEDON) there. If you previously had 50 mm (2 inches) halogen spotlights, the LED bulbs will fit the old sockets.
Knallkörper
6 Jul 2017 10:36
Mycraft schrieb:
230V LED bulbs in E14, E27, GU10, etc. sockets are more of a compromise to satisfy the mass market...
I somewhat agree. GU10 LEDs are generally "cheap" and mostly suited for retrofit applications. However, there are a few models with quite decent housings that look discreet. Without flashy elements or adjustable heads, they can be acceptable.
Soroka
6 Jul 2017 12:11
Mycraft schrieb:
Nitpicking.
So if valid objections are dismissed here as nitpicking, I guess I will limit myself in the future to pointing out bankers who can’t do basic math and similar issues...
ashley
6 Jul 2017 12:23
What would be the official solution? Installing low-voltage LEDs with a transformer?
ashley
6 Jul 2017 12:24
Knallkörper schrieb:
I would do it like this: Remove the transformer – connect a GU10 socket to the cable (99 cents on Amazon), then install a 230V LED bulb (e.g., LEDON). If you previously had 50mm (2 inch) halogen spotlights, the LED bulbs will fit the old sockets.
So, simply connect the new GU10 socket to the ceiling wires using a terminal block and install the LED bulb?
