ᐅ Climate Control: What Is the Best Approach?
Created on: 15 Jun 2017 20:50
Hausbauer1
I’m somewhat heat-sensitive. Until now, I have always lived in apartments that would get extremely hot in summer, despite maximizing shading during the day and ventilating strongly with rapid air exchange at night. Those were the days of my childhood spent in a basement apartment, where even in the height of summer the bedroom stayed pleasantly cool.
To get to the point: I definitely don’t want to deal with that in my own home. So, air conditioning is an important topic for me. My question is: what is the best way to maintain comfortable temperatures even in the peak of summer?
I have read that heat pumps can also provide cooling through underfloor heating, although the effect seems to be relatively mild. It’s also said that mechanical ventilation with heat recovery can be combined with cooling, but here, too, there are obviously fairly strict limitations. Finally, there is the conventional split air conditioning system, which certainly cools well but also consumes a lot of electricity. However, combined with solar panels on the roof, electricity costs should remain manageable since there is usually a surplus of electricity in summer that’s hard to use otherwise.
What would you recommend considering both cost and comfort? Maybe some combination makes sense, for example cooling with a heat pump via underfloor heating and additional cooling through mechanical ventilation with heat recovery – perhaps a moderate amount of cooling from two systems is sufficient in combination. Who has experience and can share knowledge and opinions?
HB1
77.willo6 Jul 2017 10:50
Especially since sunlight entering through the windows causes significantly higher indoor temperatures than those outside.
Knallkörper
6 Jul 2017 11:09
Okay, but in my opinion, it would also be sufficient if the system is capable of cooling the room to the desired temperature within 3-4 hours in terms of performance. Then, perhaps only a system half as "large" would be necessary, and the money saved could be invested in an intelligent control system or remote control.
bierkuh83
6 Jul 2017 11:27
77.willo schrieb:
Especially since sunlight through the windows causes much higher indoor temperatures than those outside.
Well, I don’t know who lets the air conditioning run nonstop with unshaded windows, but in my opinion, they should be held accountable. Otherwise, a temperature difference of 10°C (18°F) compared to outside within an hour should be sufficient...
Steffen80
6 Jul 2017 11:56
bierkuh83 schrieb:
Well, I don’t know who sets the air conditioning to blast through unshaded windows, but in my opinion, they deserve to be tarred and feathered. Otherwise, a temperature difference of 10°C (18°F) compared to outside over one hour should be sufficient...
Then you’d have to start with me. I like to sit in a BRIGHT!, air-conditioned office.
77.willo6 Jul 2017 12:11
bierkuh83 schrieb:
Well, I don’t know who lets the air conditioning run with unshaded windows, in my opinion they deserve to be tarred and feathered. Otherwise, a delta T compared to outside of 10°C (18°F) within an hour should be sufficient...
I do that. I don’t want to sit in the dark all day.
bierkuh83
6 Jul 2017 12:59
Then I will follow Stephen Hawking here, who sees "greed and stupidity as the greatest threat to humanity."
