ᐅ Is a raised basement the ideal compromise?
Created on: 18 Jun 2017 20:08
Hausbauer1
Hausbauer1
18 Jun 2017 20:08
From the beginning, it was clear to us that we wanted a house with a basement so that rooms like the utility room or heating room could be located there, providing enough storage space and possibly allowing for a hobby basement or even a guest room.
Considering the additional space you get, the costs for a basement generally seem reasonable. I recently read about the alternative of a “raised basement,” meaning a basement that partially rises above ground level and thus allows for larger window areas. This is said to save costs due to less excavation.
Here in NRW, the basement is allowed to protrude 160 cm (63 inches) on average above ground without being considered a full floor—measured from the top edge of the ceiling. So, practically, it can stick out about 140 cm (55 inches) when taking the basement ceiling thickness into account. That should enable fairly large window areas.
Of course, I wonder if it really saves money or if the additional costs end up being higher. For example, you need stairs at the main entrance and also need to find a solution for the garden exit (stairs or raising the terrace). Certainly, more plaster is required for the basement part that rises above ground, as well as insulation for the basement and better basement windows. Am I forgetting anything? Has anyone calculated this in detail or has experience?
I also came across an interesting plot where the front edge of the house must be built directly on the sidewalk (central location). What could be a solution there? You probably aren’t allowed to place the entrance stairs on the sidewalk? Would an internal solution inside the house be possible? But that would affect all floors above.
I look forward to your insights and suggestions.
HB1
MIA_SAN_MIA__
18 Jun 2017 20:18
Also consider the exterior appearance and a possible terrace when planning a raised basement...
RobsonMKK18 Jun 2017 20:29
And who needs windows in the basement?
Alex85
18 Jun 2017 20:38
Anyone who wants to use it as living space.
The whole thing is limited by maximum building height restrictions or requirements for the base height (in our region, including NRW, 30cm (12 inches) – you can forget about a high basement).
But yes, we also set the basement as high as possible to save on excavation.
11ant18 Jun 2017 20:46
MIA_SAN_MIA__ schrieb:
But also consider the exterior appearance
If the ideas from both threads are to be combined in the same house design (raised basement and flat roof with recessed upper story), aesthetics will likely be the first casualty.
Hausbauer1
18 Jun 2017 20:58
Alex85 schrieb:
The whole thing is limited by restrictions on the maximum building height or specifications for the base or plinth height (here in our region, also NRW, 30cm (12 inches) = raised cellar is out of the question).
Does this apply throughout all of NRW? Where is this regulated? I had unfortunately overlooked the base height requirement until now.
