ᐅ Carport Variation from the Building Permit / Planning Permission
Created on: 22 Apr 2017 17:15
Chriscross
Chriscross22 Apr 2017 17:15
Our architect included a carport with a storage room in our house plans right from the start. The building permit / planning permission was submitted and approved. The house is now built, but the carport manufacturer we initially chose no longer produces this type of carport. How much can I deviate from the approved plans without causing any issues? The original plan was for a carport measuring 6.5m x 9m (21 ft 4 in x 29 ft 6 in) with an integrated storage room of 3m x 6m (9 ft 10 in x 19 ft 8 in) and a flat roof. The carport is located 1m (3 ft 3 in) away from the neighbor’s property line.
Thank you for your help
22 Apr 2017 18:28
I wouldn’t go longer than the mentioned 9 meters (30 feet).
What do you have in mind?
Best regards, Yvonne
Chriscross22 Apr 2017 19:05
There should be no major changes.
Instead of 6.50 meters (21 feet 4 inches), maybe 6.80 meters (22 feet 4 inches).
The slight incline, somewhat like a lean-to, should now go straight down.
Something along these lines.
Payday
22 Apr 2017 20:48
The important factor is the 9-meter (30 feet) length along the boundary. If the carport is located at the corner, there are two boundaries, and depending on the federal state or local development plan, different maximum boundary lengths may apply.
If the garage extends more than 3 meters (10 feet) away from the boundary at the rear, the 30 cm (12 inches) should not be an issue.
Chriscross22 Apr 2017 21:01
The image might help to better illustrate this.
Site plan of a property with pavilion and carport, building boundary visible
Payday
22 Apr 2017 22:21
Which direction are you planning to widen? Will the pathway become narrower, or the area next to the property boundary? If you have 1 meter (3.3 feet) to the boundary, that can be a critical measurement. There are often regulations like “1 meter (3.3 feet) or directly on the boundary…” In that case, you may not be allowed to build as close as 0.7 meters (2.3 feet) to the boundary. You should clarify this, and your architect should normally be able to answer this without any problem. However, always keep in mind that they might be doing this for the first time ^^
