ᐅ Requesting feedback on our floor plan design
Created on: 25 Mar 2017 10:46
KingSong
Development Plan / Restrictions none, neighboring buildings
Plot size 882m² (9489 ft²)
Slope slight south-facing slope, about 1.5m (5 feet) drop over 34m (112 feet) length towards the south
Floor area ratio none
Plot ratio none
Building lines and boundaries none
Edge development yes, garage
Number of parking spaces 2
Number of floors 2 full stories, ground floor clear height 2.70m (8.9 feet), upper floor clear height 2.50m (8.2 feet)
Roof type gable roof 28°
Style
Orientation east / west
Maximum heights / limits
Additional requirements
Homeowners’ Requirements
Style, roof type, building type gable roof, modern interpretation of a Jura-style house
Basement, stories slab on grade, 2 full stories
Number of occupants, ages 4 people: M 42, F 35, F 4, F 3
Space requirements ground floor, upper floor ground floor 100m² (1076 ft²), upper floor 100m² (1076 ft²)
Office: family use or home office? both
Guest bedrooms per year 1-2
Open or closed architecture open
Traditional or modern construction modern
Open kitchen, cooking island open kitchen with half island
Number of dining seats 8
Fireplace no
Music / stereo wall yes
Balcony, roof terrace no
Garage, carport large garage 7m x 8m (23 ft x 26 ft)
Vegetable garden, greenhouse vegetable garden
Further wishes / special features / daily routine, including reasons why certain things are desired or avoided:
Bedroom facing north/east as it is the coolest room in the house and we like to wake up with sunrise; children’s rooms preferably separated from the bedroom; flush interior doors with 5mm (0.2 inch) aluminum frames; ground floor parquet flooring, upper floor vinyl/design flooring; bathroom tiles with wood look; the open space in the hallway on the upper floor should be a mix of a small second living room and play area for the children; circulation pump; controlled mechanical ventilation with humidity recovery; wood/aluminum windows
Planner: my 5 cents
-planner from a construction company
-architect
-do-it-yourself
What do you like most? Why? The west side, because we have an unobstructed view to the west over fields and forest
What do you dislike? Why? So far nothing
Cost estimate by architect/planner: around €430,000 excluding ancillary construction costs, including slab on grade
Personal budget limit for the house, including fittings: €480,000 including ancillary construction costs (excluding kitchen and garden)
Preferred heating technology: air-to-water heat pump or geothermal with baskets
If you had to give up something, which details / expansions
-could you do without: external venetian blinds, wood/aluminum windows
-could you not do without: the flush-mounted doors
Why did the design end up this way?
It evolved from many previous drafts and matured over time
Floor plan of a house: living/dining area with dining table, kitchen, bathroom, office, stairway, garage (above)
Floor plan of a house: bedroom, two children’s rooms, hallway, bathroom, utility room, dressing room.
Modern two-story gray house with large glass windows standing on an open meadow and fenced yard.
Modern gray house with glass facades; interior visible: dining room left, living room right.
Modern two-story gray facade with flat roof, terrace and garden fence.
Modern gray house with gable roof, garage on right and fenced green garden.
11ant27 Mar 2017 14:37
KingSong schrieb:
We decided not to have a window in the walk-in closet since we usually only use it early in the morning or late in the evening. There are plenty of lighting options for the times in between.
However, this means that outfits worn during daylight hours can only be evaluated for color matching under artificial light. For the walk-in closet user type "hit & run" (someone who sees the closet as a storage space, grabs an outfit, and rushes off), this is not an issue – but for the "fashion show" type, it makes a significant difference.
KingSong schrieb:
I’m also considering whether the hallway on the ground floor really needs to be 150cm (59 inches) wide between the stairs and the wall, or if 120cm (47 inches) would be sufficient.
If I wanted to avoid a sudden change in spatial perception when moving from circulation areas to living spaces, I would skip the contrast in spaciousness between the living rooms and the hallways.
j.bautsch
27 Mar 2017 15:08
I am the type of person who prefers natural daylight to better assess outfits.
120cm (47 inches) is probably enough for the hallway, but it’s not exactly ideal.
KingSong27 Mar 2017 19:39
My wife agrees with me that we don’t need a window in the walk-in closet since there is enough natural light coming through the bedroom windows. In the morning, when getting dressed, you need artificial lighting anyway, and the same applies in the evening. Also, I don’t know where you shop for your clothes, but I hardly know any store where you try on clothes in natural daylight—maybe at a flea market. And if it really is necessary, I just take the clothes a couple of steps into the bedroom to stand in natural light. Installing a separate window just for that would be a waste of money.
11ant27 Mar 2017 19:55
KingSong schrieb:
but I hardly know any store where you can try on clothes in daylight,
Exactly – a common reason for returns in brick-and-mortar stores. But well: personally, I prefer the extra closet space gained.
27 Mar 2017 20:02
With your roof pitch, an open gable is a good option, which also provides enough space for a roof window. Cleaning once a year from the inside using a ladder is perfectly sufficient, in case this comment arises.
Best regards in brief
11ant27 Mar 2017 20:13
With your roof pitch, an open gable is a good option that also provides enough space for a roof window.
With the house’s basic shape, that was also my thought, especially since I find the idea of using a roof window as a bathtub view quite appealing. However, that might conflict with the style of the "Jurahaus" (?).
