ᐅ Single-Family Home Planning: Requests for Help, Tips, Suggestions, and Feedback Welcome
Created on: 8 Feb 2016 13:59
McEgg
Since we are just slowly starting to plan our single-family home, I would like to share it here for feedback. I’m sure many people will have tips, suggestions, and even criticism that could help us. I’m trying not to write a long novel to avoid overwhelming readers and to keep it readable.
Plot details:
Key zoning plan specifications:
Our basic wishes:
About us:
We are still undecided about how to build. Therefore, I said I want to look into companies from the following categories:
Prefabricated house (timber frame construction):
We visited the prefab house center in Mannheim several times. Based on online research and recommendations from acquaintances who have built with this company, we had an appointment with Fertighaus Weiss GmbH. The consultant took a lot of time for an initial meeting (5 hours) and planned a first draft house with us. It’s basically a first idea based on what we have expressed as our wishes. As a first draft to see what is roughly possible on the plot, I think it’s okay. But it’s not yet something that convinces us. Here are just the ground floor and upper floor:
Comments:
Other appointments:
What do you think of our current approach and draft?
Plot details:
- 540 m² (approximately 5800 sq ft)
- 19 m (62 ft) wide
- Garden facing south
- Flat terrain
- Currently undeveloped
- New residential area (30 plots) in Rhein-Pfalz district
- High groundwater expected (requires waterproof basement construction, “white” or “black” tank)
- Floor area ratio (FAR) 0.3
- Total floor area ratio 0.6
- 2 full stories permitted
- Maximum wall height 4.5 m (15 ft)
- Maximum ridge height 9.5 m (31 ft)
- Gable or hip roof with pitch between 30° and 45°
- Dormers may cover up to half of each building side’s width; each individual dormer may cover up to one third of the building width, maximum 4 m (13 ft)
- Garage must be at least 5 m (16 ft) behind the street building line
- Garage allowed on only one side of the building
Our basic wishes:
- Usable basement (waterproof construction, “white” or “black” tank)
- Ground floor
- Shower bathroom
- Office
- Open kitchen-living-dining area
- Fireplace in living-dining area
- Pantry
- Entrance vestibule (?)
- Straight staircase to the upper floor
- Upper floor
- Main bathroom
- Master bedroom
- Walk-in closet
- 2 children’s rooms
- Gallery (?)
- Double garage
- With access to pantry (not sure if allowed in Rhein-Pfalz)
- Construction style
- Simple, modern, clean lines
- High ceilings
- Unfortunately, due to zoning, no upper floor without sloped ceilings possible
- Budget
- I estimate we’ll end up around 350,000 € (house only, without land), probably about 10% higher
About us:
- She: born 1982, teacher (civil servant)
- He: born 1981, executive at a large German mid-sized company (approx. 6,000 employees worldwide)
- Child 1: born late 2015, mostly just kicking, drooling, sleeping, and eating at the moment
- Child 2: still swimming like a tadpole in the Rhine
- Prefabricated houses (timber frame construction)
- Property developer (solid masonry construction)
- Architect
Comments:
- The width of 10 m (33 ft) results from 19 m (62 ft) plot width minus 6 m (20 ft) double garage (boundary building) and 3 m (10 ft) clearance to neighbor
- Negative ground floor aspects:
- No entrance vestibule
- Passage from hallway to living area too narrow
- Lower right area of living space (right next to staircase / above “office”) is too narrow (we have a large sofa)
- Ground floor
- Arrange shower bathroom and pantry vertically
- Access to pantry from kitchen side upstairs
- Position office horizontally instead of vertically
- This allows moving the staircase to the left wall of the pantry, creating more space for passage and living area
- Upper floor
- Moving the stairs causes a problem upstairs that I have not yet solved
- I generally like the upper floor layout, but because the stairs access is on the left side, I cannot reach the walk-in closet anymore
- I do not want the walk-in closet to be a pass-through room (!)
Other appointments:
- Appointment with property developer (Missivbau) scheduled for early March
- Appointment with architect scheduled for early March
Hello Yvonne,
yes, you mentioned that before. I’ll remind my wife about it again.
According to this plan, the hallway and the pantry will be about 1.30 m (4 feet 3 inches) wide and 3.60 m (11 feet 10 inches) long.
It might be possible to install a glass door as a windbreak in the entrance area where the built-in closet ends...
The proportions don’t seem right to me either.
The entrance is narrow, and the storage room isn’t really usable as such.
Meanwhile, the guest bathroom is a generous 8m² (86 sq ft).
Wouldn’t it be better to make the bathroom smaller, add a storage room between the bathroom and the stairs, and use the space saved to enlarge the entrance area with a proper wardrobe?
You mean something like this? It would of course create more space in the living area. The bathroom would probably still be large enough. You would need to check the window situation, as the one shown in the picture would likely be nicer on the street side. The path from the kitchen to the pantry would be a bit longer. Would the pantry be more practical this way?
If I move the wall behind the couch so that the distance from that wall to the exterior wall of the living room is about 4.50 m (15 feet), which I think is a good size, the hallway would be about 2.30 m (7.5 feet) wide. I would probably put a closet there for storing jackets and shoes.
Do you think that width is sufficient? What width would you consider optimal? Of course, it shouldn’t feel too narrow, but I also don’t want to "waste" too much space on the hallway.
stefanvery2 Nov 2016 18:03Personally, I would also move the couch closer to the opposite wall since my eyesight isn’t very good and I don’t want a 2-meter (6.5 feet) TV [emoji2]. But I agree with you that moving the wall would initially waste space in the hallway; as far as I can see, you already have 17-18 square meters (183-194 square feet) there.
