ᐅ Combination of tiles and hardwood flooring in the living room with an open kitchen
Created on: 22 Oct 2016 19:41
JanechanHello everyone,
We are currently building a semi-detached house and need to decide on the flooring soon. We have an open living/kitchen/dining area and originally wanted to install a uniform floor throughout. We were almost set on tiles for the entire ground floor, but are now considering hardwood instead, as we really like the look of wood floors and tiles might feel cold. However, everyone around us advises against installing hardwood in the kitchen area, so we are now thinking about how to combine both types of flooring.
Attached is our floor plan, and there are several options. We definitely plan to have tiles in the hallway as well.
How would you approach this? Tiles only in the kitchen? If so, how would you separate the areas (for example, square tiles or diagonally at the transition between the kitchen end and the corner of the hallway)? Or would you extend the tiles into the hallway area?
Our kitchen has a very light, slightly cream-colored front and a black granite countertop. Would you choose light or dark tiles? (By the way, wood-look tiles are not an option for us.)
I’m really looking forward to your advice!
Jane
Jane
Then I would choose a floor color that is darker than cream, leaning more towards medium brown or a mix of gray-brown, rather dark.
Regarding the flooring: I would use a continuous material throughout—no mixing—except maybe a separation between the entrance area and the hallway.
Parquet flooring should not be a problem for a kitchen, unless you are a bit careless with food crumbs falling on the floor.
Regards
Regards
