My partner and I are currently starting to plan our house, which is why I joined this forum. We have purchased a plot in a new development area. However, the zoning plan does not allow flat roofs, even though that is our preferred design. All attempts to convince the building authority and the municipal council have failed. The zoning plan permits all roof types with a pitch between 15° and 45°. The wall heights measured from the base to the eaves are 5.5 m (18 feet) for gable and hip roofs, and 7.5 m (25 feet) for shed roofs. To me, this seems somewhat illogical. Since the plot is almost flat, with a 5.5 m (18 feet) wall height, it’s not possible to have two full stories without sloping ceilings. Ideally, I don’t want the roof to be visible from the outside. With a shed roof, two full stories are easily possible because of the 7.5 m (25 feet) wall height.
My question is:
What do you think about planning a staggered shed roof with a 15° pitch and a wall height up to the eaves of 6 m (20 feet) — allowing for two full stories — and then extending the exterior wall up to 7.5 m (25 feet)? This way, from the outside, it would visually look like a flat roof building, but inside there would be a shed roof, visible only from above. Do you think it would be possible to get such a design approved? Is it allowed to extend the walls beyond the eaves?
Thank you very much for your feedback.
bauherr85
My question is:
bauherr85
HilfeHilfe20 Sep 2016 07:20so you would definitely be the center of attention in your village but I also believe that this wouldn’t be approved
bauherr8520 Sep 2016 08:50We are flexible with the budget, but I am estimating around 500,000 for the construction work alone, excluding the land and exterior landscaping. The living area should be between 200 and 230 m² (2,150 and 2,475 sq ft).
Knallkörper20 Sep 2016 08:52bauherr85 schrieb:
What do you think about this?
@Alex85
@Jochen104
This is not a roof.
bauherr8520 Sep 2016 08:59@Knallkörper
What criteria do you base this on to say that this is not a roof?
