ᐅ Is it possible to repair laminate flooring? Can it be replaced with new flooring?
Created on: 12 Jul 2016 10:51
F
fraubauer
Good day.
I have the following problem.
I noticed damage on my new laminate floor (including impact sound insulation, click system).
It probably happened while moving furniture into the apartment.
In a very visible spot, which will not be covered later by a runner or similar,
I found a hole/crater about 4 mm (0.16 inches) in size. The laminate is practically pierced through here.
Something seems to have fallen onto the laminate or it was stepped on with force...
Of course, this is very frustrating for me.
Can anyone advise me on what options are available?
- Is a repair recommended (using a repair kit with heated wax that is applied)?
- Or is it possible to remove and replace the affected area from the wall to the damage?
(It is about 1 meter (3.3 feet) wide and about 4 meters (13.1 feet) long)
- Or does the entire floor need to be replaced?
What is usually done in such a case?
Thank you
erika
Thank you
erika
thelastscout8512 Jul 2016 23:29Bauexperte schrieb:
What an effort .... 😕
Best regards, Bauexperte The flooring was installed by my previous landlord, and when I moved out, I was allowed to take it with me (: Back then, I was still in training, so I was grateful for every dollar I could save.
By the way, I still have the flooring today. However, it won’t be coming with me to the new house 😀
Bauexperte12 Jul 2016 23:47thelastscout85 schrieb:
My former landlord installed the flooring for me, and when I moved out, I was allowed to take it with me 🙂 Since I was still in training back then, I was glad to save every dollar I could.I can relate to that well. Just this statement:thelastscout85 schrieb:
By the way, I still have the flooring today. But it won’t be coming with me to the new house 😀could have been made clearer in relation to your later comment:thelastscout85 schrieb:
I took the laminate flooring from the bedroom with me during my last move and laid it again in the new apartment, and you can’t tell it isn’t new.Regards, Bauexperte
