ᐅ Windowpanes without frames
Created on: 7 Jul 2016 16:17
andimann
andimann7 Jul 2016 16:17
a quick question: Were the window panes delivered to you without frames and then installed into the frames on site?
I was last at the construction site Tuesday evening, and there was already a shipment of window panes (really just the triple-glazed panes, without frames!). I found that a bit surprising. As far as I know, complete windows with frames usually arrive ready to install.
Andreas
Jochen1047 Jul 2016 16:21
With us, the entire unit is delivered. However, this should not be a problem for the window installer.
Legurit
7 Jul 2016 16:23
Even separated... I think both are normal.
andimann7 Jul 2016 16:26
BeHaElJa schrieb:
Separately as well... I think both are normal.
Ok, thanks, learned something new today...
Slightly surprised regards,
Andreas
wpic7 Jul 2016 17:10
If the window or door frames exceed a certain weight, the frames and glass are delivered separately, as installation would otherwise require lifting equipment. A triple-glazed unit weighs approximately 30 kg/m² (6.1 lbs/ft²).
nordanney
8 Jul 2016 10:57
With us, delivery and installation are also separate and take place on-site (which is not a big effort, but it must be done properly).
