ᐅ Our Floor Plan / Suggestions and Feedback Welcome
Created on: 15 Mar 2016 21:50
Baufie
Since we will probably be purchasing our plot soon, we are currently in the planning phase and have created the attached floor plan together with our designer.
All our wishes have been taken into account.
The elevations are the first draft; we are working on them diligently and hope to get some input here through suggestions and criticism.
Development Plan/Restrictions
Plot size: 656 sqm (7,060 sq ft)
Slope: minimal gradient from south to east
Site coverage ratio: 0.3
Floor area ratio: -
Building window, building line and boundary: 16 m by 20 m (52 ft by 66 ft)
Edge development: corner plot (at least currently, and we hope it stays that way)
Number of parking spaces: double garage including 2 spaces in front
Roof type: gable roof
Architectural style
Orientation: northeast / southwest
Maximum heights/limits: building height 8.50 m (28 ft)
Other specifications
The south side is on the "lower" corner. To the north, there is currently a turning circle.
Owners’ Requirements
Style, roof type, building type: 2 full stories with a gable roof, clean lines
Basement, floors: basement, 2 full stories
Number of people, ages: 2 adults (38 and 36), 2 children (6 and 3)
Space requirements on ground floor and upper floor: as shown
Office: family use or home office? Yes, on the ground floor (currently still shown with a double bed)
Guest sleepers per year: max. 5
Open or closed architecture
Conservative or modern design
Open kitchen, kitchen island: closed kitchen
Number of dining seats: at least 6
Fireplace: yes, water-heated
Music/sound system wall: still undecided
Vegetable garden, greenhouse: possibly behind the garage
Other wishes/special features/daily routine
Who created the plan: designer/structural engineer, direct contract
What do you particularly like? Living and dining area; we will still adjust the chimney into the wall structure to create a corner niche of 1.00 m by 1.20 m (3 ft 3 in by 3 ft 11 in) for the corner fireplace
What do you dislike? The corner between the office and kitchen, as well as the guest bathroom, which will probably be too small for a shower
Price estimate from architect/designer: unknown
Personal price limit for the house including fittings: unknown
If you have to give up anything, which details/extensions
- can you do without: the pergola or covered terrace, this could be realized later
- cannot do without: office on the ground floor
A few notes:
The staircase is deliberately placed as shown to completely avoid the dirt area.
As mentioned at the beginning, we are still working on the elevations and are open to all criticism and suggestions, especially regarding window sizes. For example, we do not want floor-to-ceiling windows on the upper floor.
Baufie
16 Mar 2016 15:10
@Nofret: We debated the location of the laundry room for a long time. In the end, we settled on this spot because my wife likes to dry laundry outdoors and therefore prefers the short route here.
@Jochen104:
  • The style direction referred to the exterior views. From my perspective, there aren’t many corners.
  • The doors fit, I just spoke with the planner again.
  • The shower is planned in case the office is used as a bedroom in old age. We’re now unsure whether we even want this shower since the guest toilet isn’t very large.
  • The TV will go where the couch is currently placed. The couch will be moved to the exterior wall, so there won’t be a floor-to-ceiling window here. Why do you ask?
  • The second door to the guest room will probably be removed. I also find the narrowing of the corridor here unfortunate, but that’s because a service shaft runs down through the bathroom in the basement, making the corridor narrower here. Maybe we will adjust the wall so the corridor is continuous.
@all: Would you swap the storage room with the laundry room in the basement? The idea was to have a small daylight window in the laundry room. Or do you think a light well would be enough?
One more question: Would you align the office wall with the kitchen wall on the ground floor?
Jochen10416 Mar 2016 15:31
Baufie schrieb:
The style referred to the exterior views. And from my perspective, there aren’t many corners.
Leaving the garage aside, your house has 10 corners; mine only 4.
Baufie schrieb:
Doors fit, just spoke again with the planner.
Ok. I only asked because at our place, one door (guest toilet) was planned narrower. I only noticed that after a closer look at the plan.
Baufie schrieb:
The shower is intended so that the office could possibly be used as a bedroom in old age. We are also now unsure whether we even want this shower. Because the guest toilet isn’t very big.
That reason makes sense to me. Also, the shower can be used by the children sometimes. We deliberately wanted no shower in the guest toilet. This way the room stays tidier and is easier to clean. But we have a kids’ bathroom for that 🙂
Baufie schrieb:
The TV should go where the couch currently is. And the couch next to the exterior wall, which is why there won’t be a full-height window here. Why do you ask?
I liked the position of the couch facing outside. I just missed a good placement for the usually important TV.
Baufie schrieb:
The second door to the guest room will probably be removed. I also find it unfortunate that the hallway narrows here. But that’s because a service shaft comes down in the basement bathroom, making the hallway narrower. Maybe we’ll move the wall here so it’s consistent.
There seem to be quite a few shafts. Probably also because only 17.5cm (7 inches) interior walls are used. I would prefer a visible boxed-in shaft in the basement over such “botched” walls.
Baufie schrieb:
@all: Would you swap the storage room with the laundry room in the basement? The idea was that the laundry room would then have a small window with daylight. Or do you think a light well would be enough?
If that weird intermediate door and the attached wall are removed, it probably doesn’t matter much. On one hand, a longer path for laundry; on the other, for supplies 🙂
Baufie schrieb:
Another question. Would you align the office wall with the kitchen wall on the ground floor?
Yes, either extend the kitchen wall further up on the plan (which probably won’t work because of the service shaft), or move the entire office wall (towards the hallway and guest toilet) down on the plan. That would at least eliminate an unnecessary corner.
16 Mar 2016 20:59
I have looked at the floor plans: I would straighten the hallway on the ground floor by slightly enlarging the office, and on the upper floor, swap the shower and toilet (considering light/views and privacy).
Baufie
16 Mar 2016 21:01
So, I'll follow the moderator’s request and upload some images;)
Thanks in advance for any further suggestions.
Basement floor plan with laundry room, boiler room, storage room, and stairs
2D ground floor plan with kitchen, living room, hallway including stair area
2D first floor plan of a house with two children’s bedrooms and master bedroom
Plot and floor plan with marked building area and dimensions
Cross-section of a two-story house with garage and foundations
Architectural drawing of a two-story house front with windows, roof, and driveway
Architectural view of a house under construction with foundations, elevation drawing
Side view of a modern two-story house with garage, architectural drawing.
Baufie
16 Mar 2016 21:23
I looked at the floor plans: I would straighten the hallway on the ground floor by slightly enlarging the office, and swap the shower with the toilet upstairs (for light and privacy reasons).
We will straighten the hallway; then the corner will be in the office, and the hallway will appear more harmonious.
Really swap the toilet?
Jochen104 schrieb:
Leaving the garage aside, your house has 10 corners; mine only has 4.
Without the bay window and covered entrance, it would also only have 4 😉
Jochen104 schrieb:
If that odd intermediate door including the attached wall is removed, it probably doesn’t matter much. One time you have a longer route for laundry, another time for pantry access 🙂
We will discuss this again with the planner. Thanks already for your tips.
16 Mar 2016 21:50
First of all, thank you for creating the images.
Secondly, congratulations, as I know it wasn’t entirely easy for you 🙂
Counting without the garage, I see only 7 corners; ours has 6… Of course, a simple design with 4 corners, straight walls, and a roof is the cheapest but also the most boring option. I don’t like bay windows, but practical recesses are fine... Well,
I also notice some smaller issues with the window positions?
Where is the wardrobe planned (did I miss something?)
P.S. In the laundry room (what a word…), I would prefer natural daylight and a proper window.
