ᐅ Controlled residential ventilation: Is an air gap under the doors necessary?
Created on: 3 Mar 2016 13:57
WildThing
we are building with a central controlled ventilation system for the living spaces. I have heard several times that the interior doors need to be trimmed by about 1 cm (0.4 inches) after installation to allow sufficient air circulation.
Is this true? And if the doors are trimmed, the bottom edge will be “open,” without any coating or edge banding. Is that not a problem?
How is it handled in your experience?
3 Mar 2016 19:39
WildThing schrieb:
we are building with a centralized mechanical ventilation system with heat recovery. I have often heard that interior doors need to be shortened by about 1 cm (0.4 inches) after installation to allow adequate air circulation.
Is that true? And if they are shortened, there will be an "open" edge at the bottom without any coating or edge banding—is that not an issue?
How is it in your experience?
In our case, the doors were also custom ordered to size. And yes: with mechanical ventilation systems, there must be a gap—our construction plans also show the directions of air flow. The architect explained this to us as well.
Bieber0815
3 Mar 2016 22:35
And yes: with controlled residential ventilation, there must be a gap
No, it is not necessary. Air transfer can be ensured by
- a gap under the door
- a gap at the top between the frame and the wall
- drop seals with an air transfer opening
- wall vent
There may be other options as well. If you are interested, I can share a link to a site that has been explaining this well for 10 years.
If it is a door gap, it does not have to be "we have always done it this way" 1 to 2 cm (0.4 to 0.8 inches); rather, the gap height depends on the airflow rate, the desired pressure loss, and the door width.
(Air transfer openings are also a topic that seems to be completely new for my builder ops
Neige schrieb:
Company Renson’s Invisido system
Interesting, I didn’t know that. Are you familiar with Mine drop seals from Planet?
Neige3 Mar 2016 22:43
No, I’m not familiar with that, but I’ll take a look. Thanks.
Edit: I know about recesses, but not from Planet.
Sent from my mobile device
WildThing4 Mar 2016 08:09
Thanks @One00 for your link. So, you have the “overflow opening” above the doors. Did you install that yourselves? And in that area, you don’t have any spray foam or anything, it’s really open? How satisfied are you with your solution?
However, this topic doesn’t seem to be very well known among door manufacturers or installers. So far, no one has asked us if we have a mechanical ventilation system with heat recovery, and when we mentioned it ourselves to one, they didn’t know if or how much attention was needed for that.
In our execution plan, there is no information about airflow directions or special door dimensions... (Although the airflow directions are clear, since we generally have supply or exhaust depending on the room.)
Neige4 Mar 2016 09:55
WildThing schrieb:
Thanks @One00 Do you also have no expanding foam or anything in that area, so it’s really open?
The door frames are only foam insulated at specific points. By the way, I think this solution is quite good. The recesses are done quickly.
Sebastian79
4 Mar 2016 09:57
We will slightly adjust the door frame forwards or backwards to make the shadow gap a bit larger. It will then be insulated only in small areas so that the overflow opening between the door and the wall remains.
Advantage: No light, no sound – and definitely no large gap between the door leaf and the floor, which in my opinion is unacceptable...
