ᐅ Floor plan of a bungalow on a slab foundation, approximately 110 square meters
Created on: 5 Feb 2016 19:28
PortoalegreB
Bauexperte5 Feb 2016 23:34merlin83 schrieb:
I think we may have been talking past each other. I’ll try to be more specific: My garage is built with a 17.5cm (7 inch) wall right on the property line and is permitted. Would a 36.5cm (14 inch) wall be prohibited because it is insulated? If so, where is the limit? No, the law does not care about the thickness of the wall you use to build your garage; the main point is that it stays within the critical 3.00 m (10 ft) setback zone and does not cause any structural encumbrance due to its height.
merlin83 schrieb:
If 36.5cm (14 inch) is not forbidden, then I would have a technically sufficiently insulated room for the equipment. Or where is my mistake? The equipment room (HAR), especially when located on the property boundary, requires on one hand an insulated space (the equipment must be inside the insulated building envelope), and on the other hand, usually no usage other than garage/carport is permitted directly on the boundary line. The exception is semi-detached houses.
Regards, Bauexperte
Portoalegre6 Feb 2016 08:42Punica schrieb:
I think the proportions between the room sizes are not balanced.
As already mentioned, the bathroom is far too small for a T-layout.
Good luck A T-layout works with a room depth of 3.20 m (10.5 feet)
Portoalegre6 Feb 2016 08:47Punica schrieb:
I think the proportions between the room sizes don’t add up.
As already mentioned, the bathroom is far too small for a T-shaped layout.
Good luck The rooms that are important to me are perfectly proportioned.
Portoalegre6 Feb 2016 08:50Bauexperte schrieb:
No, the law does not specify the wall thickness for building your garage; the main requirement is that it stays within the critical 3.00 m (10 feet) setback zone and that its height does not create any building encumbrance.
The technical equipment located in the utility room, especially when placed on the property boundary, requires an insulated space (the equipment must be housed within the insulated building envelope). Additionally, no other use besides a garage or carport is generally allowed on the boundary line. An exception applies to semi-detached houses.
Best regards, BauexperteIt will be a technical room, not a utility roomSimilar topics
