ᐅ Carpet over underfloor heating?
Created on: 23 Jan 2016 10:58
Komposthaufen
Komposthaufen
23 Jan 2016 10:58
We are currently considering installing carpet instead of hardwood flooring on the upper floor of our planned house. However, there are warnings about using carpet together with underfloor heating due to carpet’s poor thermal conductivity. Does anyone have experience with this and can offer advice?
Regards.
Bauexperte
23 Jan 2016 11:38
Komposthaufen schrieb:
However, carpets are generally discouraged in combination with underfloor heating due to the poor thermal conductivity of carpet.
By *whom* are you being warned?
Regards, Bauexperte
Komposthaufen
23 Jan 2016 11:39
From the Internet
Bauexperte
24 Jan 2016 10:00
Good morning,
I thought so.
When purchasing carpet, you need to make sure it is suitable for underfloor heating; there is nothing else to consider.
Regards, Bauexperte
Legurit
24 Jan 2016 10:25
If necessary, you should also inform your planner about this – roughly, carpet has a similar thermal resistance coefficient to hardwood flooring:
Carpets: 0.07 – 0.17 m²K/W (0.4 – 1.0 ft²·°F·hr/BTU)
Needlefelt: 0.12 m²K/W (0.7 ft²·°F·hr/BTU)
Engineered wood flooring: 0.03 – 0.15 m²K/W (0.17 – 0.86 ft²·°F·hr/BTU)
Strip parquet (oak): 0.08 m²K/W (0.46 ft²·°F·hr/BTU)
If you hadn’t planned very thin hardwood flooring before and are now using the 2 kg/m² (4.1 lbs/ft²) rubberized stick-on carpet, it probably won’t make much difference after all.
Komposthaufen
24 Jan 2016 16:33
Thanks for the answers. It seems I was probably stressing over nothing. However, I will bring it up with the architect again.
Best regards.
